Go to Post if you've got the guts you will get the job done. - JamesCH95 [more]
Unread 01-02-2006, 09:17
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
Kop servo continous rotation modification allowed?
Does anybody remember First ruling on modifying a Hitec servo for continuous rotation? The answer is probably no, but Did First ever officially rule on it?
Unread 01-02-2006, 10:16
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
Re: Kop servo continous rotation modification allowed?
I always try to answer these questions logically.
the motors cannot be modified because that would give some teams a big advantage in robot torque or speed.
The controllers and victors and spikes cannot be modified because that would create a possible fire or safety hazard
but the servos? They are not considered motors because you can buy more and use as many as you want. There is no safety or fire hazard if you screw one up when you mod it
so logically, I would think it would be ok to modify a servo.
As alway, FIRST has the final say, and some of the rules they have this year are not logical, so I would have your team post the question on the official Q&A forum (and start modifying one now, so you will be ready to go if they say yes).
BTW: I searched CD and cannot find an answer from previous years either way, but there are instructions on how to modify servos in some older threads.
Unread 01-02-2006, 10:48
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
I would suppose that servos qualify as a "motor." Since there is not specific rule allowing them to be modified in this way or saying that their gearbox is "non-integral" I think that such modifications would be deemed illegal.
But, of course, this is just my educated guess based on past rule. As others have said, FIRST Q&A is the only real way to get this answered 100%.
Joe J.
Joseph M. Johnson, Ph.D., P.E.
Mentor
Team #88, TJ2
Unread 01-02-2006, 12:22
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
That has been the ruling in previous years through Q/A, which doesn't necessarily apply to this year as Dave Lavery quite often points out.
Unread 01-02-2006, 16:14
Stephen Kowski's Avatar
Stephen Kowski Stephen Kowski is offline
BSEE, MSEE, JD
AKA: employed
Rookie Year: 2000
Stephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond repute
Send a message via AIM to Stephen Kowski
are there any team leaders out there that can post this question on the Q&A forum?
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
Servo command confusion?!?!?!?! [527]phil Programming 9 15-07-2005 20:10
Servo Compact Design Problems!!! Dominator_Legen Electrical 22 07-04-2005 18:15
Servo Help Dominator_Legen Motors 3 11-03-2005 19:50
Servo Rotation indieFan Motors 6 13-11-2004 13:41
