Re: pic: Team Rush 27 - Shooter Concept
ya im not realy a fan of the side by side wheels either. wat i think would be alot better is putting them vertical so u dont have a problem with turning while the ball is in flight due to one whele spining faster/slower than the other. the vertical one would somewhat elimate this factor and it would be a better idea if the bottom one is spinning faster than the top to creat back-spin on the ball. although i looks realy good
Thanks for all of the great responses......
As for the gear drawing and SolidWorks. I did draw the gear in AutoCad, and I do have it in my solid models, both UG and Inventor. Though it is my general practice to leave that sort of CPU draining detail out of my drawings. Fear not, for I have built many a turret, and have designed many a spur gear......I have even milled one that was nearly twice that diameter. The side-to-side design....... Also not my favorite. We chose it after several prototypes mainly because of it's low profile. A vertical style two-wheeled shooter was becoming to tall, and a one-wheeled design didn't allow for the lowered RPM and increased torque we were looking for in a shooter. We have tons of adjustability in the design which allows us to tune the wheels for both compression and alignment. To keep both wheels spinning together we've opted to skip any sort of mechanical coupling and just tune the wheels using a tachometer. Worked well for the prototype. |
I should have looked at this post first - answers my question from the picture in your other post. Looks sweet.
Craig |
Keep in mind that if the wheels aren't spinning at exactly the same speed, the balls won't fly straight. Every motor, even if they're the same design, will spin at different speeds.
| The Death of FIRST | Anton Abaya | General Forum | 23 | 03-05-2006 17:18 |
| pic: Team Rush 27 - Up and out! | ajlapp | Robot Showcase | 17 | 08-02-2006 18:39 |
| Top 10 seasons in FIRST History | Karthik | General Forum | 6 | 01-08-2005 23:30 |
| pic: Team RUSH 27 Electrical Box | austind27 | Extra Discussion | 20 | 02-03-2005 19:41 |
| pic: Team Rush 27 - Full Bot Inventor | ajlapp | Robot Showcase | 7 | 19-02-2005 14:05 |
