Go to Post That tetra has personality! - Kevin Thorp [more]
Unread 01-02-2006, 19:30
Idaman323 Idaman323 is offline
In Theory, Our Robot Would Own.
FRC #1706
Team Role: Driver
Idaman323 is an unknown quantity at this point
Accelerometer/Gyros?
If we are using a turntable design with the shooter on top of that. And the camera find s the green light during autonomous and shoots. Do we needs all of the acceleremoters/gyros/etc hooked up? Or can we just drive forward, find the light, and shoot? BEcause we didn't put them on and I was wondering if it was a big deal just to leave them out.
I understand, the drive depends on the battery being charged but if we have a turntable for the gun, does it still need the gyros and what not?
Thanks!
TEAM 1706
2007 Judges Award, St. Louis (For our amazing ability to have bad luck)
2005 Rookie Inspiration Award, St. Louis
Unread 01-02-2006, 21:11
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
Re: Accelerometer/Gyros?
the gyro acts as a feedback device to tell the RC what the robot is doing (how fast it is turning)
if you are using the camera to lock on the light, and turn towards it, that is also a 'feedback' device.
Its up to you - the gyro and accelerometers can be used for a lot of things. In engineering there are always alternative ways of doing the same thing. If you can get your robot to do what you want without these sensors, then you dont need them.
Also, there is no requirement to put them on your robot (in the rules).
Unread 01-02-2006, 21:23
FRC #1706
Team Role: Driver
Okay thanks, I was just wondering if we needed them wiht our design. i guess we'll have to see how it goes.
TEAM 1706
Unread 02-02-2006, 13:47
Salik Syed Salik Syed is offline
FRC #0701 (RoboVikes)
Salik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud of
Send a message via AIM to Salik Syed
If you are using the camera to aim then the gyro isn't really THAT necessary. even if you are off a little bit due to voltage fluctuations in the battery the camera will still compensate
Team 701
Unread 03-02-2006, 23:20
zachriggle zachriggle is offline
FRC #1940
zachriggle is infamous around these parts
Navigation... we're using it for semi-dead reckoning during the 10-second autonomous period. We figure, even if we get knocked off course, the accelerometer should register that, and we should be able to *MOSTLY* correct for that.
