Go to Post Anyone know anything about a missing plastic flamingo from NASA HQ? I should mention before you answer that tampering with federal property, even if it's weird stuff from (Dave's) office, is punishable by painful delivery of ChiefDelphi negative rep points. - Rich Kressly [more]
Unread 01-02-2006, 22:07
Smithvillefirst Smithvillefirst is offline
Anthony Peck
FRC #1806 (Smithville First)
Smithvillefirst is an unknown quantity at this point
Using vars across multiple .c files
We have a few global variables that we want to use in both user_routines.c and tracking.c. We can not seem to declare and access them in a way that the compiler likes. We either get an error saying multiple definitions, or not defined. I've tried defining the var in a globals.h and including that in both .c files, but that doesn't work. I've tried adding extern declarations in my .c files, but no dice there either. I've tried about every combo of declaring in .c and .h files, with and without externs but nothing seems to work. Anybody know what my problem is?
Anthony Peck
Integration Manager
Team 1806
Unread 01-02-2006, 22:10
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Re: Using vars across multiple .c files
define the var as:
extern mytype myvar;
in each file accessing it, except one.
Then, in ONLY ONE file (the only without an extern declaration), declare the variable normally:
mytype myvar;
See http://www.crasseux.com/books/ctutor...variables.html
Unread 02-02-2006, 10:51
Anthony Peck
I've tried this, but it won't work. In a file globals.h, I have the following:
int myvar;
Then, in user_routines.c I have:
#include "globals.h"
extern int myvar;
I do the same thing in tracking.c, with the include and extern declaration but I get the following linker error when I try to compile:
symbol 'myvar' has multiple definitions
I access the variable inside the default_routine function, and in another function in the tracking.c file. I've tried declaring it both inside the functions, and at the top of the .c file outside of any function, but below my preprocessor directives. Nothing seems to work. Everything look fine, but what am I doing wrong? Thanks for any ideas you guys might have.
Originally Posted by Abwehr
define the var as:
mytype myvar;
Anthony Peck
Integration Manager
Team 1806
Unread 02-02-2006, 11:00
Mike Soukup's Avatar
Mike Soukup Mike Soukup is offline
Software guy
FRC #0111 (Wildstang)
Rookie Year: 1996
Mike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond repute
Never declare variables in a header file. You can extern the variables, but never declare them. If you declare the variable in the header file, the compiler tries to create the variable each time it reads the header file.
Here's an example of what you should do:
Code:
foo.c:
int myvar;
void foo(void)
  myvar = 2;
bar.c:
extern int myvar;
void bar(void)
  printf("myvar %d\r", myvar);
Alternatively you could get rid of the 'extern int myvar'; from bar.c and move it to a header file that you include in any c file that uses myvar.
Code:
foo.c:
int myvar;
void foo(void)
  myvar = 2;
bar.c:
void bar(void)
globals.h:
extern int myvar;
Unread 02-02-2006, 11:07
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
int myvar;
extern int myvar;
That's exactly backwards. You should put the extern declaration in the .h file, and actually define the variable in only one .c file.
Unread 02-02-2006, 12:38
Anthony Peck
That's what I was looking for. Everything compiled just fine. Thanks a bunch!
Anthony Peck
Integration Manager
Team 1806
Unread 02-02-2006, 20:29
mogunus mogunus is offline
AKA: Luciano DiFalcone
FRC #1350 (Rambots)
mogunus is an unknown quantity at this point
Alternatively, you could use pointers. Declare variables in main.c, declare pointers to them, and pass said pointers to the ProcessDatefrommasterUP and processdatafrommasterIO functions. Then pass them from there to whatever other functions you want to have access to those vars.
... one of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs.
-- Robert Firth
using eclipse dasRatsel Programming 82 02-01-2006 13:20
Multiple Files EricWilliams Programming 4 30-03-2005 15:51
Combining multiple objects in different files into the same scene and file? DinkyDogg 3D Animation and Competition 8 19-02-2005 19:14
problem with .c files incognito_NICK Programming 5 31-01-2005 13:19
Multiple files usage punarhero Programming 2 12-01-2003 11:45
