Db9 port
if the db9 serial port is fried, shouldn't the whole camera stop working?
i am asking this when i tried to calibrate the camera using labview, the serial port did not even come up on the aplication. however i was able to uploadd kevin's camera code to the rc. even though the camera did not move. also i accenditly attached the ttl adapter to the rc wrong(backwards) and one fo the pins was touching one of the relay pins, the adapter got realy hot. i quicly turnedoff the rc and removed it. could that have fried the ttl adapter and that is why when i upload kevin's code to the rc the camera does not move or sends data to the terminal window? Last edited by GOshin : 02-02-2006 at 19:45. |
Re: Db9 port
You should first try to get the camera to respond using LabView (or last year's Java GUI, or a direct serial connection like Hyperterminal). Once you can do that, then you can go on to get it communicating with the Robot Controller.
If your TTL-to-RS232 converter was misconnected in such a way to make it hot, I'd guess it's toast. You can play with the terminal assignment definitions in Kevin's camera code and tell the software to use the program port for its camera communication, but that'll prevent you from simultaneously using the program port for the Bells&Whistles menu communication. |
| CMUcam2 Serial Port Diagnostics | Kevin Watson | Programming | 13 | 18-02-2006 15:05 |
| TTL port to a serial port on a demo board | ImmortalAres | Programming | 16 | 09-07-2005 23:44 |
| Updated: Serial Port Driver Code | Kevin Watson | Programming | 4 | 05-02-2005 18:39 |
| Camera DB9 / Calibration Port | roboticsguy1988 | Programming | 10 | 26-01-2005 14:15 |
| New Serial Port Driver | Kevin Watson | Programming | 16 | 09-01-2005 01:56 |
