Go to Post As goes with all of my advice on CD, try it yourself and make up your own mind. I'm just suggesting things based on experience. See what works for your team. Follow my suggestions to the letter, mix and match them, or even throw them completely out the window. It's all about you and your team. - DampRobot [more]
Unread 03-02-2006, 00:00
groves groves is offline
Steve Liggett
None #1213 (Groves)
Team Role: Teacher
groves is just really nicegroves is just really nicegroves is just really nicegroves is just really nicegroves is just really nice
pic: 1213 TARDEC GROVES DRIVE PLATFORMS 2
greencactus3 greencactus3 is offline
occra 23.
AKA: ryo
None #1481
greencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to all
Send a message via AIM to greencactus3 Send a message via MSN to greencactus3
Re: pic: 1213 TARDEC GROVES DRIVE PLATFORMS 2
very nice. looks lighter than last years.. whatkind of tires are those? ever think that the wedgetop and roughtop might be better or are those good enough?
Unread 03-02-2006, 00:58
Steve Liggett
None #1213 (Groves)
Team Role: Teacher
Well the wheels are from NPC and they have remarkable traction. They have a durameter of around 60 (which is quite sticky). NPC makes good robot parts. you can find their products at:
http://www.robotmarketplace.com
Unread 03-02-2006, 01:13
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Are those Colson wheels, or similar to colson wheels?
Also, I'm interested in learning how you couple your axle to the dewalt tranny output. Also, is there a bearing right next to the dewalt tranny output?
Unread 03-02-2006, 01:31
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
We use 1/2" keyed shaft with transmission end turned down to fit the 0.3 x 0.25 double-D.
Yes, a bearing on the wheel mount next to the transmission - just mirror what you see on the outside wheel mount.
Unread 03-02-2006, 07:52
Peter Matteson's Avatar
Peter Matteson Peter Matteson is offline
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Peter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond repute
I thought the post said TARDIS
Direct Drive Four Motor System Collin Fultz Technical Discussion 42 02-11-2006 12:03
pic: 1213 GROVES HS / TARDEC CONTROLS groves Robot Showcase 10 26-02-2005 06:59
pic: 1213 GROVES HS / TARDEC TITANIUM FP GEAR groves Robot Showcase 7 20-02-2005 12:00
pic: 1213 GROVES HS / TARDEC DRIVE SYSTEM groves Robot Showcase 5 17-02-2005 13:03
pic: 1213 GROVES HS / TARDEC LIFT SYSTEM groves Robot Showcase 6 17-02-2005 06:24
