Go to Post I love it when awards go to the right people. - David Kelso [more]
Unread 03-02-2006, 15:16
Rick TYler Rick TYler is offline
A VEX GUy WIth A STicky SHift KEy
VRC #0010 (Exothermic Robotics)
Rick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond repute
Spinning Cylinders
Commercial conveyor rollers are either heavy, expensive or both. I have a strong preference for light, cheap and simple, so I have made a variety of cylinders during prototyping. We do not have a machine shop, so I have been trying different ways of attaching a roller to a shaft with other ideas.
We have:
1. Made a wooden cylinder, pinned to a 1/2-inch shaft by drilling holes through the wood into the shaft. This worked well, but was heavy.
2. Used a hollow shaft with friction-fit plugs in the ends (didn't work so well).
3. Inserted threaded fasteners into plugs fit into the ends of a hollow aluminum cylinder (we unscrewed one of them which should have had reversed threads but didn't).
4. Created a free-spinning cylinder pegged to the shaft by an external metal fitting fixed to the shaft with a set screw (this worked well, but took up a lot of shaft room).
I'm just interested in hearing how other teams without the ability to cut keyways dealt with this, and how you engineered lightweight, Poof ball-friendly rollers.
Exothermic Robotics Club, Venturing Crew 2036
VRC 10A, 10B, 10D, 10Q, 10V, 10X, 10Z, and 575
Unread 03-02-2006, 16:12
Peter Matteson's Avatar
Peter Matteson Peter Matteson is offline
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Peter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond repute
Re: Spinning Cylinders
While we have a machine shop I think our method could be done with just a drill press.
We make a free spinning roller (Al tube with bearings pressed in the ends) attached to the frame using hex head cap bolts with the heads cut off.
Mount a gear or pulley to one end with 4 screw.
The gear method requires a motor mounted closely to direct drive the gear on the roller. The pulley allows for a remote motor mount.
Having the drive right on the end of the roller only takes up room that the balls wouldn't go into anyway.
Hope that helps.
Unread 03-02-2006, 16:23
Paul Copioli's Avatar Unsung FIRST Hero Woodie Flowers Award
Paul Copioli Paul Copioli is offline
President, VEX Robotics, Inc.
FRC #3310 (Black Hawk Robotics)
Rookie Year: 2000
Paul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond repute
Rick,
It looks like you guys can put plugs in hollow tubes. Have you tried PVC? PVC (Charlotte Pipe, specifically) is lightweight and tough and you can put almost any kind of friction surface on with simple hand tools.
-Paul
Unread 03-02-2006, 16:33
Not2B's Avatar
Not2B Not2B is offline
AKA: Brian Graham
FRC #0862 (Lightning Robotics)
Not2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond repute
Well, I'm not saying they are good... but... here is what we did with next to no tools.
(1) 12" long 1" PVC tube
(2) 1" long 1" PVC tube
(2) 1" PVC coupler
(2) Bearing that comes with the skyway wheels (we ordered a bunch of them)
(1) metal shaft
- Drop the bearing into the coupler. There is a lip on the inside of the coupler that will stop the bearing from passing through.
- Sandwich the bearing between the lip and a 1" hunk of PVC. Make sure the bearing you have doesn't get squished by PVC and make sure it still spins freely.
- Push this unit onto the 12" long PVC tube
- Do the same on the other side.
- Run rod down the center
- The roller should now spin freely on a stationary shaft.
Now to the powering it part. We are using timing pulleys and belts. Replace the timing pulley set screw with a LONGER screw. Loctite or fix it so that it doesn't touch the metal rod. Slip pulley onto rod, with the hub fitting into the 1" PVC. (Buy a pulley so that the hub will FIT inside the 1" PVC also.) Dremel a notch into the PVC for the long setscrew replacement. When we mounted the rollers, we also used spacers to hold the pulleys in place. It freaks the students out, but when it's all spaced out, nothing can come apart.
Seems to be working right now... cheap, light, and easy to set up roller assy line staffed with people new to robotics.
Brian Graham
Unread 04-02-2006, 00:33
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
Now I don't know how much money your team has but I was recently turned onto a these really nifty quicklock clamp collars. http://www.mcmaster.com/nav/enter.asp?pagenum=964 (Third item down) When you tighten them, the inside gets tighter and the outside gets larger allowing you to clamp shafts onto outer pulleys. They cost from about 30-60 dollars depending on the size. My team probably isn't going to use them this year, but in the future they're definitely going to be a go to item for all our projects.
Team Website
Unread 04-02-2006, 02:36
A remarkably helpful set of responses. Thanks!
Spring return or loaded Cylinders falconmaster Pneumatics 4 13-01-2006 17:16
Polar direction between two cylinders reilly Pneumatics 4 18-02-2005 11:38
Pneumatic Cylinders MASherry Pneumatics 1 09-01-2005 18:49
Custom pneumatic cylinders duckshepherd Pneumatics 7 24-01-2004 20:39
Gear spinning wrong way? Jnadke CD Forum Support 11 10-05-2003 10:23
