Go to Post The most important deisgn criteria is always performance in any of the parts / systems we design. But we do try to abide by the saying -- if it doesn't look good (right), it probably isn't good (right). - Adam Freeman [more]
Unread 03-02-2006, 23:21
zachriggle zachriggle is offline
FRC #1940
zachriggle is infamous around these parts
IR Receiver
If I've read correctly, the IR Receiver needs 12v. The Digital IO port only provides 5v. We set the IR Receiver to then have its own line AND fuse... but it refuses to show any activity that the RC can detect. The light on the Receiver turns on\off as it should... but it's sending nada down the signal cable.
How is it SUPPOSED to be hooked up?
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
Infrared sensor...receiver emayank Electrical 3 25-02-2005 19:54
How to connect the R/C receiver?! Tim Skloss Robotics Education and Curriculum 7 10-12-2003 16:34
Need info on how to build temp. receiver and transmitter archiver 1999 5 23-06-2002 22:01
