Go to Post In the absence of a valid game hint, the natives in CD tend to get restless and resort to this sort of pun-ishment of one another. - David Brinza [more]
Unread 03-02-2006, 23:33
zachriggle zachriggle is offline
FRC #1940
zachriggle is infamous around these parts
PWM Cables
Several questions about the beloved (hated?) PWM cables.
1.) Is there a cheaper place to get them than IFIRobotics? $5 a pop is VERY steep.
2.) Where might I be able to get the connectors to make our own?
3.) Are there any rules about soldering directly to the RC? (Assuming that it was heat-shrink-wrapped (sp/grammar?) so as not to make contact with other parts...
4.) The Servos come in the Generic and Kubosomethingoranother connectors. Maybe if we could find said connectors...?
Unread 03-02-2006, 23:45
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Re: PWM Cables
I believe any electronics place will sell the correct terminals to you.. look around for them.
Don't even think about soldering to the RC. You *will* melt something. Also, what happens if at at a competiton you need to replace one of the wires, or your RC becomes damaged? That won't be fun.
Search around this forum, you can find the correct connectors, and probably a crimp tool to use with them
Unread 04-02-2006, 02:26
Chriszuma's Avatar
Chriszuma Chriszuma is offline
Jack of all trades
AKA: Chris Hammond
FRC #0068 (Truck Town Thunder)
Chriszuma is just really niceChriszuma is just really niceChriszuma is just really niceChriszuma is just really nice
Send a message via AIM to Chriszuma
Re: PWM Cables
Yes, soldering onto the rc is a bad idea, but I can understand why you would want to. On our team, we use a silicon adhesive called RTV to make sure the cables don't fall out. It's very similar to rubber cement. In fact, I bet you could even use rubber cement. Now, if you wanted to get really leet with it, you could make a giant connector that clamps onto the edge of the RC and holds all the pwms in place. That would probably be much less ghetto-looking (depending on how you build it of course). We did something like that with our victors.
EDIT: check these out: http://www.robotmarketplace.com/mark...e_ifi_esc.html
2006 T3 World Tour: Great Lakes - Waterloo - Palmetto - IRI
2006 Awards: Motorola Quality - RadioShack Innovation in Control
My website: http://zuma.phire.org/
Truck Town Thunder's website: http://trucktownthunder.com/
Unread 04-02-2006, 13:54
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
ahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond repute
Send a message via ICQ to ahecht Send a message via AIM to ahecht Send a message via Yahoo to ahecht
Re: PWM Cables
You might want to check this thread and this thread
Zan Hecht
Scorekeeper: '05 Championship DaVinci Field/'10 WPI Regional
Co-Founder: WPI-EBOT Educational Robotics Program
Alumnus: WPI/Mass Academy Team #190
Alumnus (and founder): Oakwood Robotics Team #992
"Life is an odd numbered problem the answer isn't in the back of the book." — Anonymous WPI Student
Bad Pwm cables Greg Needel Electrical 7 18-01-2006 23:13
PWM Extention Cables: 4 Shall Be the Limit Joe Johnson FIRST Tech Challenge 4 12-04-2005 23:33
PWM cables: too fragile? what fixes/precautions? BillCloyes Control System 18 14-03-2005 17:34
The PWM Cables amateurrobotguy General Forum 1 22-02-2005 17:42
Loss of signal in PWM cables. archiver 2001 6 23-06-2002 23:29
