Go to Post Step 1: Get Drill Step 2: Insert 1/2"-1" bit into drill Step 3: Drill Those Speed Holes! - Adam Richards [more]
Unread 02-04-2006, 11:26 AM
FTtyler's Avatar
FTtyler FTtyler is offline
FRC #1561 (Purple Ducks)
FTtyler is an unknown quantity at this point
Balls getting stuck in hopper
We are having trouble with ball getting stuck at the bottom of our hopper.
Does anybody have any ideas?
Unread 02-04-2006, 11:29 AM
Safarley2901's Avatar
Safarley2901 Safarley2901 is offline
AKA: Steve Farley
FRC #0808 (Mechanical Mayhem)
Team Role: Leadership
Safarley2901 has a spectacular aura aboutSafarley2901 has a spectacular aura aboutSafarley2901 has a spectacular aura about
Re: Balls getting stuck in hopper
How are we going to know what your hopper looks like. You shoul.d at least post a picture.
2005 Pittsburg Regional Finalists
2005 Cleveland Regional Semi finalists
Unread 02-04-2006, 11:46 AM
CarpeDiem CarpeDiem is offline
FRC #0135
CarpeDiem is an unknown quantity at this point
try using an agitator to move the balls at the floor of the hopper.
Unread 02-04-2006, 11:48 AM
Starke Starke is offline
Producer at The RoboSportsNetwork
AKA: Matt Starke
FRC #0174 (Arctic Warriors); (Alumni: 340 (GRR), 1126 (SparX))
Starke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond repute
I'm guessing that you are using a gravity feed hopper. one thing that we have found is that no matter how you plan for it, the balls will get stuck. i suggest a agitator mechanism that keeps the balls moving and will not let them get stuck. something as simple as a turning lazy susan that allows the balls to continue to move around.
Team 340 | G.R.R. | Alumni/Mentor | 2003-2007, 2010
Team 1126 | SparX | Engineer | 2008-2009
FRCDesigns.com | Engineer | 2011 - Present
Team 174 | Arctic Warriors | Advisor | 2012 - Present
Unread 02-04-2006, 12:36 PM
Anime-niac_2.9's Avatar
Anime-niac_2.9 Anime-niac_2.9 is offline
Japanese-crap freak(NOTE AVATAR)
AKA: Alex Abenoja, A-Squared, & Anime
FRC #0599 (Robodox)
Anime-niac_2.9 will become famous soon enough
I have to agree. We can't read minds, especially through computers. if you can't post a picture you should at least tell us what kind of hopper you have.How did your team design this?
THE ROBODOX FORUM
Reading: Suzumiya Haruhi no Yuutsu by Tanigawa Nagaru
Religion: Haruhiism
Unread 02-04-2006, 12:40 PM
FlyingDutchman FlyingDutchman is offline
FRC #1566
FlyingDutchman will become famous soon enoughFlyingDutchman will become famous soon enough
my team is having the same problem you are but we are or were using a funnel type loader but then went to a square track with rounded edges.
Unread 02-04-2006, 12:46 PM
Rick TYler Rick TYler is offline
A VEX GUy WIth A STicky SHift KEy
VRC #0010 (Exothermic Robotics)
Rick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond repute
Having played with models of several approaches, the one that works best is to use a single-ball channel of some kind: either ramps or a spiral. In Top Gun the balls never have a chance to jam. During their short stay in the robot the balls are always lined up on tracks, either dropping via gravity or rising on pressure belts. If you don't ever let balls get side-by-side, you won't ever have to worry about them jamming up.
In bulk material operations, stirring mechanisms are sometimes used to prevent granular stuff from plugging up chutes and outlets. We didn't go this route so I don't have anything to add from experience, but it seems to me that a short "stir stick" attached to the F-P motor with its low-speed, high-torque transmission intact might be just the thing. If you are using pneumatics, a short piston pushing upwards on a "thing" might jostle the balls when they jam.
Exothermic Robotics Club, Venturing Crew 2036
VRC 10A, 10B, 10D, 10Q, 10V, 10X, 10Z, and 575
Unread 02-04-2006, 05:52 PM
AV_guy007's Avatar
AV_guy007 AV_guy007 is offline
AKA: Sam
FRC #0177 (bobcats)
AV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud of
i would sugest a agitator of some sort sorta like an electirc paint bALL hoper
Team 177
bobcat robotics
BLUE ALLIANCE CREW MEMBER
Next event attending: Kickoff 08- Manchester NH With TBA
Unread 02-04-2006, 06:12 PM
FRC #0599 (Robodox)
Launching jammed balls = (possibly) robot spewing confetti all over the arena.
You should be careful about this. If the ball ends up jamming and they jam inside then launch them with, say, a pitching mech then this may happen. Most likely your team will be flagged for it and run the risk of being disqualified. That is, of course, bad and will mean that in the end you designed and built for six full weeks, sacrificing sleep completely to get this project done, and it fails.
YOU HAVE BEEN WARNED!!!!!!!!!
THE ROBODOX FORUM
Religion: Haruhiism
Unread 02-04-2006, 06:14 PM
Not2B's Avatar
Happy Birthday! Not2B Not2B is offline
AKA: Brian Graham
FRC #0862 (Lightning Robotics)
Not2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond repute
And if an Agitator would work, but you don't have room for a motor and arm, you could add a "shake and shimmy" button. Drive the drive forward and backward a few times quickly and shake the whole robot.
It goes without saying... loktite would be a good idea if this is the route you take.
But - please post a picture.
Brian Graham
Unread 02-04-2006, 06:21 PM
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
maybe this is illegal... but what if you mount your compressor to the hopper? even if you aren't running a complete pneumatics system... it would surely keep the hopper vibrating
Unread 02-04-2006, 06:26 PM
FRC #0599 (Robodox)
I am not sure either, but I am sure that you could at least mount the copmressor next to the hopper. I am sure that the hopper won't virbrate as much, but maybe just enough. Enough is dependant on your design. Its all about design. don't tell me it's strategy because that is very dependable on design.
THE ROBODOX FORUM
Religion: Haruhiism
Unread 02-04-2006, 06:33 PM
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
This is the belt fed, magazine, revolver debate. Our team is going with the revolver. We have a basket with a paint stirrer type paddle that sweeps the balls to a hole in the bottom of a basket. they then drop into the firing mech. By it's design the balls get jostled. Feeding the balls is proving a little challenging unless a team is going for a all at once 10 shot autonomous strategy.
Unread 02-04-2006, 06:44 PM
FRC #0599 (Robodox)
Good call to jostle the balls. If they were just left to allow gravity to do all the work you may not be loading at all. THAT WOULD CERTAINLY SUCK.
Code:
#include<stdio.h>intmain(){intloop=0;printf("Good Job");for(loop=0;loop==76;loop++){}return 0;}
THE ROBODOX FORUM
Religion: Haruhiism
  #15   Spotlight this post!
Unread 02-04-2006, 07:35 PM
shimarikakari's Avatar
shimarikakari shimarikakari is offline
The intuitive view
AKA: Lucas
FRC #1540 (Flaming Chickens)
Team Role: Electrical
shimarikakari is an unknown quantity at this point
If your team uses a gravity-based hopper the way ours does, I would recommend a spiral, since it's completely passive and you won't have to add any more motor weight. If you find that a spiral alone doesn't help, though, then you might want to add an agitator. I have to say I like the idea of mounting the compressor on the hopper - and I went and searched through the rules (starting on page 20 of The Robot), which said nothing about mounting pneumatics except that you have to use the preexisting threads. Since I assume you don't plan to drill any new holes in your compressor, that would be a great idea.
Knowledge turns chaos to order.
How will the balls be scored? ChuckDickerson Rules/Strategy 7 01-26-2006 08:28 PM
New Jersey Regional Status Aignam Regional Competitions 144 07-21-2004 05:04 PM
Thoughts on the competiton balls Petey Regional Competitions 26 03-14-2004 09:31 AM
Good strategy? tkwetzel Rules/Strategy 45 02-17-2004 09:18 PM
Will ANYONE mess with the black balls? archiver 2001 0 06-23-2002 10:35 PM
