Go to Post I'm nervous for those awesome rookie teams that you may not know about much but that just come and do awesome with some fantastic strategy...Rookies rock. - Eugenia Gabrielov [more]
Unread 04-02-2006, 15:20
Conan Conan is offline
FRC #1137
Conan is an unknown quantity at this point
Problems with the gyro
Our team is having problems with our gyro. We are using the KOP gyro with Kevin Watson's gyro code. I'm pretty sure everything's been implemented properly. We tried to just compile the code that Kevin provided, and the output results don't make sense.
The gyro_angle output starts are zero. What happens from there varies. I haven't been able to find a definate pattern. Sometimes when we turn it the output displays exactly what we feel it should. However, other times, the results don't make any sense. We might turn the gyro (slowly), and the gyro_angle does not change at all, while sometimes we can set the gyro down on a table and the gyro_angle goes wild and gives random values.
We can't really pinpoint the cause of the problem, but if any of you have encountered anything close, please share. Thanks for all of your help.
Gyroscope Code Kevin Watson Programming 65 01-03-2008 23:46
Yaw Rate Gyro Problems RetroKamikaze Programming 3 27-01-2006 20:55
Updated: Example Gyro Interface Code Kevin Watson Programming 2 28-03-2005 04:36
Example gyro code released. Kevin Watson Programming 60 17-03-2005 18:32
Wierd gyro code problems...pls help Salik Syed Programming 4 14-03-2004 01:29
