Go to Post Its just going to be a dirt game. We are going to be using shovel bots to dig for gold. Anyone who strikes oil gets the 100 point bonus! - Uberbots [more]
Unread 04-02-2006, 17:29
Kyveck Kyveck is offline
FRC #1014 (Dublin Robotics)
Kyveck is an unknown quantity at this point
ADC code effecting motor outs???
Our robot's motors seem to be receiving some sort of signal even when all pwm outs are hardcoded to zero. We systematically turned off sensors and bits of code, until we isolated the problem with the adc software. Unless we disable the adc code, (by commenting out the adc initialization or the adc/timer interrupt routines) the drive wheels act as if they are set to 10 or 20 above neutral, instead of 127. If we enable the joystick and pull it back about 10 or so, the wheels stop. If we set one wheel to be mapped as (255-p2_y) then ten forward or so stops one wheel and speeds up the other, and vice versa. If we change the sampling rate from 200Hz that we were using to 800Hz, then the wheels spin much faster, but in the same manner.
If anyone has any clue what's going on, I would be very grateful for insight. I realize that both ways that we have found to stop the motor movement have the net effect of not causing any adc interrupts, but I don't see what could be going wrong. The dashboard viewer continues to read neutral pwm values for all RC pwm outs. The gyro is on analog in 1, and the motors are on pwms 13 and 15. We have patched in Kevin Watson's gyro and adc code, version 0.4. Once again, if any one can help, we'd all appreciate it.
KLW,
Controls Software Lead,
Team 1014, Dublin Robotics (Bad Robots)
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Analog-to-Digital Converter Code Kevin Watson Programming 29 17-02-2008 13:07
adc code problem railerobotics Programming 6 24-01-2006 22:26
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
heres the code. y this not working omega Programming 16 31-03-2004 15:18
