Go to Post IMO the main idea behind FIRST is for the mentors and students to work together to produce a machine that the students could never have produced on their own. - Tim Sharp [more]
Unread 04-02-2006, 20:35
EHaskins EHaskins is offline
Needs to change his user title.
AKA: Eric Haskins
no team (CARD #6 (SCOE))
EHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond repute
Send a message via MSN to EHaskins
Robot Runs in full Reverse
I am using the camera code from kevin's website and have modified it alot, i have been using the Arcade 1-Joystick drive that is commented out in the defult
code. My problem started when i tried to switch two a Two Joystick drive system. My problem is the robot runs in full reverse. So i made my Program print the values from p1_y, p2_y, pwm03, and pwm04(the drive pwms). But what confuses me is the p1_y and p2_y print as 127 when the joystick is centered but pwm01 and pwm02 = 0. if i move the joystick the pwm values do not change. My code is below:
pwm03 = Limit_Max(p1_y);
pwm04 = Limit_Max(p2_y);
my 1 joystick code is below:
pwm03 = Limit_Max(p1_x + p1_y - 127);
pwm04 = Limit_Max(p1_x - p1_y + 127);
Can anybody help?
[moderated]: A Challenge: YOU Rewrite G25 Tom Bottiglieri General Forum 10 30-03-2005 21:18
How much do you design before kickoff? Allison K General Forum 19 07-12-2004 21:32
what kind of robot will win? Bcahn836 Championship Event 44 12-04-2004 00:02
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
