Go to Post I don't care if my team wins. I care if they try their hardest to win. - pfreivald [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition > LabView and Data Acquisition
Unread 05-02-2006, 16:37
Calvin Calvin is offline
Calvin has a spectacular aura aboutCalvin has a spectacular aura about
error window during tracking...
- The CMUcam2 is connected through the serial port on the computer.
- Using a PWM wire to give power through the controller.
- In LabView for serial port, I selected COM1.
- Than I clicked the "Run" button.
- Everything is running fine.
- I click on Grab frame
- than I click on the color I want to track.
- Than the "Start Grabbing Binary Pixel Maps"...
- The camera begins to track!
- After about 5 seconds I get the following error...
"The application is closing becuase of a reported error. You should confirm that the correct serial port..." (the same message you get when the camera is actually not connected to the serial port.
- YET even after the message appears the camera continues to track!
This happens everytime!
please help!
Unread 07-02-2006, 14:45
Re: error window during tracking...
OK, I figured out what the problem was... The camera was not receiving enough voltage. (I used the power from the EDU-robot previously.)
Moving robot while tracking with camera questions... Steve Orr Programming 6 02-02-2006 22:24
Need a realistic Statics Problem sanddrag Technical Discussion 10 05-12-2005 15:07
Camera Tracking Problem cprogrammer Programming 1 18-02-2005 15:00
Programming Problem: Extremely Frustrating chantilly_team Programming 19 12-02-2005 23:00
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
