Go to Post I wonder if it could be... Nah, that would just be way too... Never mind. . - dlavery [more]
Unread 05-02-2006, 21:49
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Anodizing - has anyone tried it at home?
Has anyone tried doing aniodizing at home? Doesn't seem like an incredibly complicated or expensive process. From what I read, all you need is some battery acid, distilled water, some electric current, some fabric dye, and some boiling water.
Has anyone tried it? How were the results?
Unread 05-02-2006, 22:07
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
Re: Anodizing - has anyone tried it at home?
229?
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Unread 06-02-2006, 00:52
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
We've tried it with small items. It works well enough, I suppose, but we still haven't figured out the best way to make the electrical connection to the part being anodized. Often the connection itself will anodize first, cutting off the current flow to the part.
When it does work, though, the results are most impressive. It's not hard, just be safe working with the acid.
Jason
Unread 06-02-2006, 01:02
Team Role: Teacher
What did you use for the current and where did you get the acid? Do you have any pictures?
Unread 06-02-2006, 11:26
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
FRC #0254 (The Cheesy Poofs)
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
I've found that drilling a hole, tapping it, and screwing in some aluminium wire works well.
When 296 tried homebrew anodizing last year, we used a really big 12V manual battery charger that put out about 40 amps. The acid was ordered for us through the school's chemistry dept.
I wrote a post here describing our process - it's far from being perfect, but the general idea is there. I'm anxiously awaiting 229's whitepaper, and hoping to get some tips from it to improve our own process.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 06-02-2006, 12:25
Tim Delles's Avatar
Tim Delles Tim Delles is offline
Since 2001.
FRC #0078
Tim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond repute
Yes we have done our on home anodizing this year with some of the parts on our robot. Our head machinist who was did most of the anodizing for the team is still getting all of the documentation together. It will be up on our website (team229.org) as soon as he gets it all together.
Timothy Delles - Clarkson University
2011 - Present: FRC Team 78 - AIR Strike
2011 - Present: VEX Team 78 - AIR Strike
2010 - 2011: FRC Team 3280 - Rhode Rebels
2001 - 2009: FRC Team 229 - Division By Zero
KRUNCH 79 and Extreme Makeover: Home Edition krunch79prez General Forum 50 17-05-2005 11:54
Home DNS Server? sanddrag IT / Communications 14 08-03-2005 02:09
**FIRST EMAIL**/Advance Material List for the 2005 Competition Now Available! Travis Hoffman General Forum 85 08-01-2005 00:16
Home DDR, Just Cause It's Cool Eugenia Gabrielov Chit-Chat 13 17-08-2004 17:30
Mountain Home & 'The Brawl' archiver 2000 0 23-06-2002 23:20
