Go to Post We need to train teams from the very beginning to become self-sustaining... so we can offer a full experience to FIRST students... - Bob Steele [more]
Unread 06-02-2006, 08:40
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Maxi Block Wiring Technique
Now that teams are really getting close to finishing, I wanted to remind everyone who are using the Maxi block of a few things. Make sure when you insert the #6 that all wire strands are inserted before tightening the holddown screw. When you insert the #10 on the output side, strip 1" of insulation from the end of the wire and fold over the strands before inserting into the block. You may have to "form" the bundle with pliers to get it to fit, but it makes a much more reliable connection when you tighten the screw. I would not recommend #12 wire be used in this application although a similar technique may give you a lower resistance connection.
Al
WB9UVJ
www.wildstang.org
________________________
Stinger Fuse Block and Power Distribution Block Don Wright Electrical 2 30-03-2004 10:45
Warning! Check the screws on your Maxi fuse block! Roland Electrical 1 16-03-2004 21:59
Do we need to use the gnd stud and MAXI fuse block Noah Melamed Electrical 14 03-03-2004 20:38
Distro block, maxi fuse box, and ground stem ErichKeane Electrical 25 20-02-2004 07:19
Anyone knowwhere to buy maxi block distribution block? BrianB Kit & Additional Hardware 0 23-01-2003 12:46
