Go to Post Machinery tends to make chips fly into weird places. Lathes and mills are particularly good at this, though drill presses are skilled as well. - Karibou [more]
Unread 06-02-2006, 15:11
shamu1001 shamu1001 is offline
FRC #1888
shamu1001 is an unknown quantity at this point
Some ways to measure distance during autonomous
First off, I'm completely new to the forums, never posted here before, so tell me if I'm violating any rules or such. =)
My team's finally getting to programming autonomous mode for the competition and the first question that came up was naturally: "how do we measure distance?" After brainstorming for a while we settled on two easiest (or seemingly easiest) ways of figuring out the distance our robot has traveled:
1) Timer - we can determine the time it takes for our bot to accelerate to a certain speed and same for deceleration and plug the rest in the distance/time formula. This methods is perhaps the easiest, but seems very unreliable, mostly because the motors never spin up the same way, and this inconstancy should get the bot at least a foot off target.
2) A distance measurer of some sort. By this I mean a device that literally rolls on the ground counting the rotations, which we can then multiply by circumference and figure out the distance. My only real problem with this method is the method of output - a problem that can be overcome.
I was wondering if any of you could pin point any flaws in my logic here or recommend a better way of measuring distance that the bot's traveled.
Also, feel free to discuss any means of measuring distance in this thread.
Eldar (Sum of all Forces - ΣF - Team #1888)
A Warning to Human Players During Autonomous The Lucas General Forum 21 07-04-2005 02:29
Setting Autonomous Settings from OI Tom Saxton Programming 15 27-03-2005 11:45
Despite what IFI says, you can configure autonomous from OI... TedP Programming 19 31-03-2004 10:09
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
