Bannner IR sensor Measures Ball Exit Velocity
The banner IR sensor has a range ~1' using blue/green poof balls
(IR doesn't reflect from balls with a black half, Visible LED type may - TBD) I conducted a test yesterday (prelim) using a 1+ meter AL pole over the ball exit path with 2 sensors attached directed downward, 1m apart black output lead pull up = ~2.2mA, (produces neg. going ball pulse) 5.6k to 12v or 2.2k to 5v) Oscilloscope used for time between their falling (leading) edges. 83.3ms = 12m/s (1/.0833) NOTE: In lieu of Oscilloscope (or external electronic timer) RC may be used with software to measure time: between two sensors using 2 input ports (above) or one port to measure pulsewidth for Simple method (below) Example: measured 60ms on 12.5" skyway direct driven by lg CIM at 12.6V (~2500 rpm) so 1/.06 = 16.7m/s The 2 sensor method eliminates ball dia. and edge dropoff errors at cost of 2nd sensor by measuring leading -edge start to leading -edge stop times ----------------------- Simple 1 sensor method: (assumes sensor sees full 7" ball dia): assumes 7" ball diameter =measured path leading to falling edge = pulsewidth Also requires blue/green balls (IR reflection is not reliable with BLACK balls) the Velocity in m/s is 1/(5.624*pulsewidth_sec) 1 / ( (39.37"/m /7"ball)*pulsewidth_sec) Example: pulsewidth of 15 ms = 11.85m/s 12m/s = 83.3 ms/m /5.634 = 14.8ms for 7" ball path realistically sensor likely senses a bit short of 7" due to the sphere edge slope. Measure the test ball(s) dia + Perform Edge detection test for an accurate dia. to use for better accuracy -- 6.9 or ? note select the white sensor output w/pullup R to +V for positive going pulses Dale.Hall@earthlink.net Team 294 Redondo Beach, CA note: m/s meters/sec ms = millisec (1/1000 sec) |
Re: Bannner IR sensor Measures Ball Exit Velocity
Do you think this would work using the banner retro reflector and sensing the ball as a blocker rather than a reflector? Then it wouldn't be sensitive to the black side of the ball.
Gary,
A separate emitter & detector would eliminate the black IR absorption problem at the cost of a bit more complexity, i.e. two wired & optically aligned devices per location (+ may need to shield ambient w/ tube or use modulation) (1 loc pulse width of 7" ball or 2 loc's for distance traveled reducing error from dia & beam pos on ball) Some teams may only have balls that are half black. then I suggest the simpler method, spray paint test ball (black half or all) Verified - works/repeatable: simpler: one device position per loc, self aligning / shielding (sensivity adj) I set up this test in 15 min w/old real time scope (DSO or storage better) I was impressed with the results of two sensor time repeatability and promising 1 sensor approach using 7" ball width to measure exit velocity (pro: sensor close to exit, con: error if beam not centered on ball) looks very promising, i.e. "simple as possible but not simpler" A.E. ??? re: retro-refl Our IR & Vis Banner Sensors contain emitter & detector & range adjustment in one compact package and rely on retro reflected beam. Broken beam approach requires physically separate Emitter & Detector & likely a hood (or modulated?) and good stable optical alignment Dale(294engr] |
Thanks. We are playing around with this as well. The IR sensor is listed as "diffuse" and the visual red sensor is listed as "retro-reflective", but the wavelengths aren't much different between the 2 sensors while the range is significantly different, so I wasn't sure if there was some difference in design that would make them behave differently.
I wasn't sure if the detection spectrum was sufficiently different that it would react better to a specific retro-reflector target while ignoring a different diffuse target (the ball) by tuning the sensitivity. |
Either sensor may be used with a reflector, i.e blocking mode. IR sensor is effective > 1' effective to detect all the ball colors, without separate Emiter / Detector (re: my earlier reply - just need to position reflector and look for loss of signal in code.) |
| Where does the ball exit your robot? | sanddrag | Technical Discussion | 18 | 25-01-2006 16:42 |
| Team 125 Ball Shooter Prototype! | Brandon Holley | Technical Discussion | 21 | 21-01-2006 00:07 |
| Ball Recirculation Question | Nuts4FIRST | Rules/Strategy | 23 | 15-01-2006 15:35 |
| Experimental Ball Drive | Sepsis900 | Technical Discussion | 16 | 31-10-2005 16:59 |
| 2004 Game | BBFIRSTCHICK | General Forum | 112 | 19-04-2003 17:12 |
