We have designed our base to use 5/8" shaft, but are having trouble finding good wheels for them. We've looked at skyway, but we'd really prefer to use a solution with conveyer belt material. If any team has a suggestion on where to buy them, or 6 7" or 8" wheels lying around that they'd be willing to sell, drop me a line.
Re: Wheels Needed
We've taken the 6" Skyway wheels included in the kit and just screwed 1" roughtop conveyor tread on them, and glued it down. They appear to work quite well, and I imagine it would be easy to simply do that for the 8" wheels included in the kit. the only problems i forsee are that they might not be wide enough for your purposes, and i don't know if you can get 5/8" bearings for them.
Alternately, IFI sells 6" and 8" traction wheels, however they are only available in 1/2" and 3/8" bore. I imagine modification would be easier on these than on the skyways wheels though. |
Re: Wheels Needed
What you are looking for is certainly not an easy find. Can you take 1/2" axle? What diameter do you need? Does it need to be a live or dead axle?
Re: Wheels Needed
Does anyone know any wheels that can fit to a 5/16 shaft, metal hub, and rubber on the outer ends?
Re: Wheels Needed
One solution might be to use these:
MSC part number: 35375278 Oil impregnated bronze bushings. they are 3/4" OD 5/8" ID and cost $.42 each. then just set them into the hubs on the stock wheel chair wheels and put them onto your shafts. Just make sure your shaft is something other than bronze. Steel would be best. You might want to help them out a bit with some light oil. Cheers |
Re: Wheels Needed
you could make your wheels, thats what we did.
here is the best picure of last years wheels i could find, this year they are allmost identical. http://www.lasarobotics.org/gallery/...05&id=050052_G |
Re: Wheels Needed
Re: Wheels Needed
Re: Wheels Needed
Over the years I've come to the realization that there are not all that many wheels with keyway (or ready for keyway) bores out there on the market. If it's something specific that you want, you'll have to make it yourself. Sometimes you'll get lucky and find something that fits what you are doing, but it is fairly common to have to manufacture a solution (at least hubs) yourself.
#10
Re: Wheels Needed
Takes 5/8" shaft, light aluminum sprockets. Available at local go-kart shops; http://www.azusaeng.com/. Call them; they are very helpful. Ceal Craig Industry Coach, Team 1120 |
| Getting A Bot To Turn | Andrew Blair | Technical Discussion | 20 | 16-10-2005 23:49 |
| Four Wheel, all steering, non-omniwheel, ONE power/motor source drive | FizMan | Technical Discussion | 31 | 27-04-2004 12:12 |
| Lots of Wheels and F = u x N | archiver | 2001 | 17 | 23-06-2002 23:37 |
| Power Wheels parts needed: Will trade, sell soul, etc. | archiver | 1999 | 13 | 23-06-2002 22:27 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
