Go to Post You don't have to build a robot to be on a robot team. This isn't about the robot, it's about learning. - engunneer [more]
Unread 06-02-2006, 22:57
JoelP JoelP is offline
whats the P for? Pazhayampallil
FRC #1155 (Bronx Science Sciborgs)
Team Role: Leadership
JoelP is a jewel in the roughJoelP is a jewel in the roughJoelP is a jewel in the rough
Send a message via AIM to JoelP
Small motor used as sensor
In order to measure the RPM of the wheel used as the shooter, would it be legal to connect a small dc motor, not in the KOP, to the shaft of the wheel so that when the wheel is turned by a KOP motor, the small motor generates a current which is connected to the RC analog inputs.
I'm pretty sure using a small motor as a sensor is legal by the rules regarding to custom circuitry, but it doesn't hurt to double check.
Bannner IR sensor Measures Ball Exit Velocity Dale(294engr] Technical Discussion 4 15-02-2006 23:57
Making a Sensor Board SpaceOsc Technical Discussion 11 15-05-2004 12:46
heres the code. y this not working omega Programming 16 31-03-2004 15:18
Banner Sensor Programming Problem 2Crisis Programming 4 24-02-2004 13:40
Quick Optical Sensor Question zorro Technical Discussion 10 21-01-2003 06:39
