Go to Post Things are not always as simple as they seem. - Paul Copioli [more]
Unread 07-02-2006, 01:21
Rick TYler Rick TYler is offline
A VEX GUy WIth A STicky SHift KEy
VRC #0010 (Exothermic Robotics)
Rick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond repute
HIGH torque shooter
More power.
1. Assume you are one of those amazingly well-equipped teams that can machine their own gearboxes.
2. Design gearboxes that use three CIMs per side.
3. Shifted one way, two small CIMs are geared down to run at the same speed as a large CIM. The output is run via a timing belt up to a single 8-inch shooting wheel (top launcher design for maximum backspin) running at roughly 2500 rpm. The speed is controlled by a feedback sensor.
4. The wheel is therefore driven by six CIMs.
5. Each transmission can be shifted into "Drive" where the motors are geared down appropriately to drive the 6WD chassis and disconnected from the shooting wheel.
Since the 'bot will not shoot on the move (really difficult anyway), the drive train can be used for either shooting OR moving.
What problem does this solve: the shooting wheel's recovery time drops as close to zero as possible. Weight is kept very low. Strong drivetrain.
Will anyone build a 'bot that uses the drive motors to power the shooting device? I'll bet I'm not the only one that thought of this.
Exothermic Robotics Club, Venturing Crew 2036
VRC 10A, 10B, 10D, 10Q, 10V, 10X, 10Z, and 575
Unread 07-02-2006, 07:20
DjAlamose's Avatar
DjAlamose DjAlamose is offline
AKA: Teh Albie
FRC #0279 (Tech Fusion)
DjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to behold
Send a message via AIM to DjAlamose
Re: HIGH torque shooter
I really don't know why you would need six motors to run a shooter... There are other ways of getting enough power to shoot the balls. I can tell you right now we aren’t using a motor, springs, pneumatics, or even electronics at all to shoot the ball. Plus were using 3' wheels on our shooter, there is no need for 8inch wheels at all. When the 21st comes along ill share our secrets, but not now. Plus we can still shoot 10 balls in around 5-6 seconds.
Plus the timing belt that was used to get the power up there would more than likely get stripped after about 3 shifts, unless they were from a stand still. Plus being able to shoot on the fly really helps.
WHAT TIME IS IT????? 279!!
2006 GLR Safety Award (2nd year in a row)
2005 National Xerox Creativity Award
2005 National Curie Quarter Finalist w/ 1126 and 180
2005 Buckeye Regional Champs w/ 67 and 274
2005 Buckeye Regional GM Industrial Design Award
2005 Buckeye Regional Safety Award
2005 GLR Quarter Finalist
2005 GLR Xerox Creativity Award
2005 GLR Safety Award
2004 Nationals Curie Division Finalist
2004 GLR Champs
2004 Buckeye Delphi Driving Tomorrow Award
2004 Buckeye Quarter Finalist w/ 1001 and 869
2003 GM Industrial Design Award GLR
2001 National Champs
Unread 07-02-2006, 08:07
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
I believe said mech. would violate the KISS principle.
Unread 07-02-2006, 11:42
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
60 and 254 powered their winch off the drive train in 2004.
Unread 07-02-2006, 11:52
Unsung FIRST Hero
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Rookie Year: 2000
JVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond repute
Which weighs less:
  • 2 Super-CIM motors for a shooter
  • 1 pneumatic cylinder, and required motion transfer components to shift the drivetrain to a shooter.
Could be a light-weight solution, for those who do not want to move while shooting.
-JV
In the interest of full disclosure: I work for VEX Robotics a subsidiary of Innovation First International (IFI) Crown Supplier & Proud Supporter of FIRST
Unread 07-02-2006, 15:12
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
190 also had a similar drivetrain for their 2002 robot. They had a CVT transmission that would drive the robot, but it could also be shifted to pull two of the mobile goals up to their robot. This idea is possible, and I wouldn't be surprised if there was a team who actually did something similar to this, even if they only used 4 small CIMs.
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Unread 07-02-2006, 16:06
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Team Role: Mechanical
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Originally Posted by DjAlamose
...Plus were using 3' wheels on our shooter...
Your using 3 foot wheel!?
Unread 07-02-2006, 19:44
Plus we're using 3' wheels on our shooter
I'm impressed. Where do you store the balls before shooting, in a side-by-side hopper? Let's see, 3-foot diameter times Pi, hmm, 9.42 feet, or 2.87 meters. Unless you are using a two wheel design (the mind reels), you would only need to run that wheel at 500 RPM to shoot the ball at 12 m/sec. Let's see, a FP runs nearly that fast at the next-to-the-last gear in the gearcase, so are you just hanging a modified FP on each side of the wheel?
Whatever happens, I want to see a pic of that robot posted here on CD, OK?
Unread 08-02-2006, 11:43
DjAlamose's Avatar
AKA: Teh Albie
OPS! I sooooooo meant to say 3" not 3'. Sorry, wow I don’t even know how you could do that. You would have to be very careful in planning that...
We aren't using motors to power the shooter! or pneumatics, or springs! Technically speaking were not even using gravity. The only problem for us is even small amounts of friction are bad so we had to beef up a few things....
2004 GLR Champs
Unread 08-02-2006, 12:25
Schneidie's Avatar
Schneidie Schneidie is offline
AKA: Marc Schneider
FRC #0177 (The Bobcats)
Schneidie will become famous soon enoughSchneidie will become famous soon enough
Originally Posted by Rick TYler
More power.
We are usung 2 small CIm's and are having no problems with our shooter, and we are using Andy Mark gearboxes, so there is no combination.
Schneidie
Cheap Torque Measurement? ChuckDickerson Motors 15 13-06-2005 13:57
Newton Rankings Joe Ross Championship Event 14 23-04-2005 12:00
What does the Chairman’s Award have to do with a robot contest? Ed Sparks Chairman's Award 32 15-02-2004 13:39
St. Louis anyone? Jeremy_Mc Regional Competitions 8 07-02-2003 12:06
Gear Woes Simon G Technical Discussion 14 24-01-2002 16:31
