Go to Post Why silence the rude ones and naysayers when you could have the students learn to deal with them? - JackG [more]
Unread 07-02-2006, 11:45
Lightposter Lightposter is offline
FRC #1954
Lightposter is an unknown quantity at this point
CIM Motor polarity question.
Hey,
I'm opening this thread because I didn't find any threads that answers my question...
Can I change the polarities of the CIM motors on the Victor? (Not the Victors power source supply, I mean the motors connections).
Thank you!
Unread 07-02-2006, 11:51
Unholy Unholy is offline
electrical / makeshift programmer
AKA: Daniel
FRC #1402
Unholy is an unknown quantity at this point
Send a message via AIM to Unholy
Re: CIM Motor polarity question.
Originally Posted by Lightposter
Hey,
Thank you!
Ok, it depends on what you want to do. Most of the time it's just better to write your program that will allow you to run however you want to run (clockwise or counterclockwise) without having to keep track of the polarities.
Unread 07-02-2006, 11:56
FRC #1954
My problem is with the CIM Motors, the forward reacts faster than the backwards and on the transmtion - when motors are placed one against the other, thier directions are opposite... That's why I want to reverse the polarities.
Unread 07-02-2006, 11:59
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
yes, you can swap the wires on the OUTPUT of the victor to make a motor run the other way
but this will not make it run at the same speed in reverse as it will going forwards. You usually need to tweak your SW to get the forward and reverse running motors to run at the same speed.
Unread 07-02-2006, 12:03
FRC #1954
Thank you, I gonna check it out
CIM Motor Count Tobaby817 Motors 2 27-01-2006 11:58
6 CIM Motors? psquared89 Kit & Additional Hardware 16 09-01-2006 08:47
cim motor power question Zippiot Motors 16 16-02-2005 20:40
Another CIM Question Carlo Motors 4 14-02-2005 22:02
