Go to Post ... if there is no standard against which you determine success, then you can never fail. - dlavery [more]
Unread 07-02-2006, 17:33
kevin.fort kevin.fort is offline
President-Team 1001
FRC #1001 (Hacksaw Robotics)
kevin.fort is on a distinguished road
Send a message via AIM to kevin.fort
Short circuiting the camera
Is it possible to short circuit the camera? we lost function on our camera after we plugged the port that is supposed to receive info with a pwm that gave it power, the other possibility we think is that we grounded the transmitter by putting the cable in upside down?
any help with this problem?
we had the camera working perfectly before it got plugged in the wrong way
We build our bots with hacksaws
websites too: http://hacksaw.brush.googlepages.com
Unread 07-02-2006, 17:36
Rocketboy's Avatar
Rocketboy Rocketboy is offline
Programmer at work, Pilot by heart
AKA: Daniel Schoessler
FRC #1317 (Digital Fusion)
Rocketboy will become famous soon enough
Send a message via ICQ to Rocketboy Send a message via AIM to Rocketboy
Re: Short circuiting the camera
Does it still turn on?
If soooo...
Try plugging the servos back into the camera and using the Camera GUI to send commands to the camera.
-- Unofficial Google Advocate --
I soloed my
"Skyhawk" before I even soloed my car!
Unread 07-02-2006, 23:44
Unholy Unholy is offline
electrical / makeshift programmer
AKA: Daniel
FRC #1402
Unholy is an unknown quantity at this point
Send a message via AIM to Unholy
It is a possibility. One of my buddies was working with the camera and apparently plugged it in incorrecty, and we ended up with a burnt servo and a burnt camera. Check your servos. Fortunately, one of the local teams was not going to use a camera, so they donated theirs.
Unread 08-02-2006, 01:53
sparkydp sparkydp is offline
AKA: David Page
FRC #0435 (Robodogs)
sparkydp is on a distinguished road
there is also an on/off switch at the top of the camera, can't tell you how many times that's been our problem.
Unread 08-02-2006, 22:43
AKA: Daniel
FRC #1402
Heh, I hear ya.
Unread 13-02-2006, 22:09
JakeM's Avatar
JakeM JakeM is offline
FRC #0781 (Kinetic Knights)
Team Role: Mechanical
JakeM is an unknown quantity at this point
Last years camera got fried. There was definately smoke and it left an awful taste in the air. If it smells burnt, it just may be.
CMU Camera kills robot controller if not found. Chris_Elston Programming 21 27-03-2006 14:30
How To Use the Google Camera generalbrando Kit & Additional Hardware 2 07-02-2006 16:00
Camera Short Circuit? MustangRobotics Technical Discussion 3 18-01-2006 14:42
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
