Programming Help - Autonomous
Hey guys, I need help with programming and the autonomous mode. What is the "_SIMULATOR" used for? I noticed that its an #indef but where is it actually defined at to make this condition TRUE? Because I noticed that it needs to be TRUE in order to make the autonomous mode execute without setting everything to TRUE manually. Thanks for any help.
Re: Programming Help - Autonomous
_SIMULATOR is for simulating the RC in MPLab - not what you want.
To run autonomous, you need to enable the autonomous_mode byte. Check the Programming forum. |
Build a switch box for operator interface (see IFI robotics for pin out) use the enable/disable input and the autonomous input.
| White Paper Discuss: C Programming and Autonomous Modes for Newbies | cbolin | Extra Discussion | 3 | 09-01-2008 19:32 |
| Autonomous Programming Guide | cbolin | Programming | 2 | 16-12-2004 15:13 |
| Autonomous Programming Competition Signup List | SilverStar | Programming | 36 | 13-05-2004 15:09 |
| How do you do the autonomous programming? | Ryan Collings | Programming | 11 | 07-02-2003 19:38 |
