Go to Post Remember that it's not what is on the outside of the shirt that matters, it's what is on the inside. - dtengineering [more]
Unread 07-02-2006, 21:07
amateurrobotguy's Avatar
amateurrobotguy amateurrobotguy is offline
Lead Programmer/Senior Engineer
Rookie Year: 2000
amateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these parts
Emergency Help Needed on Main Board and Camera
Note: this is an blurb of the e-mail sent to IFI.
Next, when we turn on the robot, with the default cmucode, the terminal windo just says >ifi when reset/turned on and nothing else; even with debugging mode turned on in the code. Kevin Watson, who wrote the default code, states in his FAQ that if nothing is returned, the main board is bad. Is this our case, or are we doing something wrong with the camera. We have all the connections (ttl, servos, power, etc.) made properly and the code is default, and the servos seem to not be getting any power, since the rotate freely(thus the need for the diagrams to trace where power is lost).
Thanks.
I quit FRC over 2 years ago (more if you're reading this past 2010).
Camera Servo Problems pi_guy578 Programming 2 28-01-2006 13:17
