Go to Post PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part. - dlavery [more]
Unread 07-02-2006, 22:37
Ceal Craig's Avatar
Ceal Craig Ceal Craig is offline
Team Role: Leadership
Ceal Craig is a glorious beacon of lightCeal Craig is a glorious beacon of lightCeal Craig is a glorious beacon of lightCeal Craig is a glorious beacon of lightCeal Craig is a glorious beacon of lightCeal Craig is a glorious beacon of light
Large CIM Motor Bias
Has anybody seen a notable amount of motor bias on the large CIM motor? we had a mockup for our shooter with the CIM mounted turning the wheel one way (ball exiting the bottom) and decided to have it exit the top instead, but with the motor mounted in the same manner, basically.
We *think* we are seeing a much reduced RPM (say 1500 instead of 2000). Not certain.
Any body seen anything like this on the new Large CIM?
Thanks for any input!
Ceal
Large Cim Motor? Fishdude404 Motors 1 27-01-2006 22:36
Breaker for Large CIM Gamer930 Electrical 4 27-01-2006 07:52
Large CIM Gary Bonner Motors 2 24-01-2006 19:57
IGES Model of Large CIM Motor Madison SolidWorks 7 16-01-2006 13:27
Large CIM motor specs ryan_f Motors 4 13-01-2006 21:38
