Start of Match
Which way do you turn at the start of autonomous mode to score points?
Re: Start of Match
You need to be facing away from your alliance station. If you are behind your robot and next to the field barrier and facing the other side of the field, you will be scoring in the goals on your right. If you are red, you will score at the blue player station.
Re: Start of Match
Re: Start of Match
Re: Start of Match
Josh |
Re: Start of Match
Your robot can face any way you want it to as long as the robot is within the starting box. I don't have the dimensions for it but you can angle your robot some, I’m not sure how much you will be able to because that depends on the size of the box. I do know that it is larger than the size of your bot so you won’t have too much to worry about. If the box just happens to be 48x48 than your robot can be angled in any way you want it too. If your robot is facing twords the middle of the field then your goals will be to your right.
Thanks
Re: Start of Match
Re: Start of Match
#10
Re: Start of Match
Re: Start of Match
| 2005 Palmetto Regional | Billfred | Regional Competitions | 115 | 15-04-2005 00:19 |
| 2005 West Michigan | pathew100 | Regional Competitions | 59 | 09-04-2005 12:56 |
| 2005 Lonestar Regional Awards, Congratulations all teams! | dez250 | Regional Competitions | 29 | 08-04-2005 20:48 |
| Falling over at the start of the match | archiver | 2001 | 2 | 23-06-2002 22:43 |
| Quickie Ideas | Robby O | General Forum | 6 | 23-08-2001 12:27 |
