Go to Post "The lowly snowflake is very fragile, but look at what they can do when they stick together" - Wayne Doenges [more]
Unread 08-02-2006, 14:25
Keith Watson Keith Watson is offline
FRC #0957 (WATSON)
Keith Watson is just really niceKeith Watson is just really niceKeith Watson is just really niceKeith Watson is just really nice
Search Servo Initialization Caution
The default search code initializes the camera pan/tilt servos with this code.
Code:
    if(new_search == 1)
        new_search = 0;
        temp_pan_servo = 0;
        temp_tilt_servo = Tracking_Config_Data.Tilt_Center_PWM;
    else
        // search code
    PAN_SERVO = (unsigned char)temp_pan_servo;
    TILT_SERVO = (unsigned char)temp_tilt_servo;
Note that the pan servo pwm is hardcoded to zero. If you have changed PAN_MIN_PWM_DEFAULT from zero to something else then hardcoding to zero is incorrect. Change the line to:
Code:
        temp_pan_servo = Tracking_Config_Data.Pan_Min_PWM;
Keith Watson - Professional Software Engineer
No relation to "Kevin" Watson, who created the camera tracking code.
Unread 09-02-2006, 01:05
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
Re: Search Servo Initialization Caution
Code:
 if(new_search == 1)
new_search = 0;
temp_pan_servo = 0;
else
// search code
Code:
Hmmm... I wonder what the heck I was thinking when I did that? Oh well, since I can't possibly explain this away as an undocumented "feature", I guess we have to call it a bug <grin>.
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Unread 09-02-2006, 02:13
FRC #0957 (WATSON)
I found it by reading the code to understand the algorithm. The rest of the code was all nicely parameterized.
Unread 09-02-2006, 07:49
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Donut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond repute
You may want to keep temp_pan_servo or temp_tilt_servo the same for a new search as well; we ran into a problem where the camera would catch the target as it spun all the way back to 0 (as it does this the tilt angle increases, which is why it caught it on the way to the left but not the right), lose it when it got there, initialize a new search and have us repeat over and over.
Mozilla / FireFox Search Plugins Brandon Martus Announcements 7 06-06-2005 10:41
search white papers? sirbleedsalot CD Forum Support 3 03-04-2005 17:09
teach rookies how to search Ken Leung CD Forum Support 2 17-01-2005 00:03
20 second search interval sanddrag CD Forum Support 4 14-02-2004 08:52
Whacky C Complier behavior Larry Barello Programming 12 26-01-2004 22:15
