Wiring the robot in inventor.
Can anyone give me a walkthrough of wiring in inventor. I currently know of the different piping commands, but am unable to find a wiring command. Any help will be welcomed. We have a control board that needs wiring, and if you can help me, it would be greatly appreciated.
-The Mad CADder |
Re: Wiring the robot in inventor.
Reply to vV,
Inventor Pro 10 has wiring harness creation built in. Can't help much more because we haven't gotten that far yet. |
you might want to try private messenging Robert Thacker- . he is one of the inventor guys on our team and h really knows what hes doing. last year, a kid who graduated wired the robot in inventor, but im sure rob knows how to do it as well, seeing as it has to get done for this year ![]() |
Are there any drawings of the wire fittings? By fittings i mean ;example; the part between the controller board and wire.
Use Sweep comand and a work plane over your electronics board.
I hope this helps. |
I saw a tutorial on the wiring/plumbing features somewhere on the autodesk website.
I found this article a couple months ago. It helped me out quite a bit, although I haven't gotten that far on our recent CAD. http://manufacturing.cadalyst.com/ma....jsp?id=180772
Hopefully it'll help you... |
There should be a book called "Routed Systems: Getting Started" that came with the inventor package. It's got instructions on how to make flexible tubing, wires, harnesses and pretty much anything else for the electrical system. Chapter 8 and beyond is what you'll want.
#10
*checks vKOP* As far as I can find, there are only two in the vKOP ("Terminal Supply Bag" folder), but they should be pretty easy to make. I'll mess around with it next time I get a chance and maybe post a model or at least instructions. |
#11
In 103 we wired our robot last year. There are two ways of doing the wiring, our way looks more like a schematic (what we wanted). If you want I can walk you through it one day just IM me I have inventor here. Jaymacdaddy0204
#12
One piece that makes wiring in inventor easier, wehn using inventor 10, is having anderson connectors and crimps to use as your endpoints. then you create a new segment, and add waypoints until it fits your desired wire path.
#13
The Mad CADder aka "Lazer" (pictures coming soon) |
#14
Can't quite remember but, it may have been on disc 4?
#15
Yeah, it's on the disc with the modules and content center stuff. An easy way to discover If you have all of that is to try runing design accelerator, and trying to make a sprocket or two. If you can't, you don't have the content center and modules. (yes, they're worth a total re-install)
| Robot Weight Limit: Rule Conflict | Specialagentjim | Rules/Strategy | 10 | 06-08-2005 17:52 |
| Honda Motor Co's humanoid robot | Mirza95vx | Math and Science | 26 | 10-04-2005 12:42 |
| [moderated]: A Challenge: YOU Rewrite G25 | Tom Bottiglieri | General Forum | 10 | 30-03-2005 21:18 |
| Is allowing a practice robot good for FIRST? | Matt Adams | General Forum | 38 | 19-01-2005 11:35 |
| Need to import robot made in inventor into 3dsmax, HELP! | anish | 3D Animation and Competition | 1 | 03-03-2002 13:53 |
