Go to Post Getting a swerve to drive predictably and effectively is arguably harder than designing and building it. - Holtzman [more]
Unread 08-02-2006, 18:35
iwdu15 iwdu15 is offline
FRC #0811
iwdu15 is an unknown quantity at this point
IFI Error
hi, im getting an error in the IFI_Startup.c file. Its a syntax error in this bock of code:
extern far rom struct //--->error on this line saying "syntax error"
unsigned short num_init;
struct _init_entry
unsigned long from;
unsigned long to;
unsigned long size;
entries[];
_cinit;
we have not done anything to the code, this is straight from the default code...so if anyone else is seeing this error or has a fix for it....itd b appreciated
Unread 08-02-2006, 18:39
Tureyhall Tureyhall is offline
AKA: Thomas Hall
FRC #0668 (Apes Of Wrath)
Tureyhall will become famous soon enoughTureyhall will become famous soon enough
Re: IFI Error
what's on the line BEFORE the syntax error line? check to see if you missed a semicolon. it will usually complain about the line AFTER the missing semicolon.
/*Nerd Camouflage*/
2005 SVR - 668+1072+840 - Semifinalists.
2006 SVR - 668+1280+1693 - Finalists.
2007 SVR - 668+604+624 - Quarter-finalists, Xerox Creativity Award, two highest scores (290-2, 128-0) at SVR.
2007 Nat's - TBA.
Unread 08-02-2006, 19:22
Greg Ross's Avatar
Greg Ross Greg Ross is offline
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Rookie Year: 1998
Greg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond repute
Send a message via AIM to Greg Ross Send a message via Yahoo to Greg Ross
Re: IFI Error
If you haven't modified this file (which normally you wouldn't need to) then I suggest you delete it, and unzip a fresh copy from the distro. In my experience, it's all too easy to accidentally modify a file when all you're trying to do is look at it. If you look carefully you MAY find an errant keystroke somewhere between this line and the end of the _startup routine just before this declaration.
Greg Ross (The Grammar Curmudgeon formerly known as gwross)
S/W Engineer, Team 330, the Beach 'Bots
<--The Grammar Curmudgeon loves this cartoon.
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!" Hunter S. Thompson
"Playing a practical joke means doing something mean and calling it funny." Me
Unread 09-02-2006, 18:11
FRC #0811
Re: IFI Error
yea...well this one is my bad, ends up my IDE was buggy and was throwing a syntax error where it shouldnt have been...thanks for the help anyway, sorry about that
Error in IFI Loader natis Programming 1 20-01-2006 17:15
IFI Loader Error Team905Animator Programming 6 12-01-2006 22:40
MPLink Error cloudago Programming 2 01-02-2005 23:00
IFI Loader Problems BrendaB Programming 3 24-01-2004 22:45
Basic Run Error BBFIRSTCHICK Programming 10 02-04-2003 22:43
