Go to Post OMG are you saying we are going to have a question mark game element next, that would be crazy - Greg Needel [more]
Unread 09-02-2006, 00:29
rwhidby rwhidby is offline
FRC #0519
rwhidby is an unknown quantity at this point
Old and New
My name is Ricky and I am from team 519. I have two questions. Can we use the power distribution block from 05, and if we can use it, can we use the ground screw that came in the 06 kit with it.
Thanks in advance
Ricky
Team 519
Unread 09-02-2006, 00:45
Mike Schroeder's Avatar
Mike Schroeder Mike Schroeder is offline
Gone the way of the dinosaur
AKA: "Big Mike"
Rookie Year: 1999
Mike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond repute
Send a message via AIM to Mike Schroeder Send a message via Yahoo to Mike Schroeder
Re: Old and New
Included in the rules were :
Originally Posted by 2006 FRC Manual
<R43> Specific items allowed include:
• Additional HITEC HS-322S servos.
• Additional Victor 884 Speed Controllers and Spike Relays, as needed.
• Additional solenoid valves, air cylinders, and connecting fittings.
• Teams may purchase either one additional 4-slot Maxi-block circuit breaker panel OR one 2005 FRC
circuit breaker panel, and utilize it on their 2006 robot in addition to the circuit breaker panels provided in
the kit of parts.
© FIRST 2006 FIRST Robotics Competition Manual, Section 5 – The Robot, Rev A Page 13 of 30
• Teams may utilize one or two additional small CIM motors (part #FR801-001) in addition to those
provided in the kit of parts. This means that you may use up to four, and no more, small CIM motors on
the robot.
and Ironically there is also a link :
http://www2.usfirst.org/2005comp/Dra...STRIBUTION.pdf
that shows how the electronics have to be layed out if you choose to use the 2k5 IFI power distro panel
its amazing what you can find when you read the manual and check the documents and updates
GOT SEARCH?
"We choose to go to the moon. We choose to go to the moon in this decade and do the other things, not because they are easy, but because they are hard"-JFK
Unread 09-02-2006, 07:52
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Old and New
In quiring minds want to know...Why if you use the IFI breaker panel would you want to use the ground stud?
Al
WB9UVJ
www.wildstang.org
________________________
Unread 09-02-2006, 12:54
Elgin Clock's Avatar
Elgin Clock Elgin Clock is offline
updates this status less than FB!
AKA: the one who "will break into your thoughts..."
FRC #0237 (Black Magic)
Elgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond repute
Send a message via AIM to Elgin Clock
Re: Old and New
Well... part of my mind says that "hey, using 2 ground studs opens possibilities to adding more electronics, cause you have 2 posts to attach ground wires to."
But, then the second half of my mind says "hey, wait a minute! won't having 2 ground studs close the system, and/or shunt it"?
So, i usually have 2 logics, and it's a constant struggle trying to decide which logic to use.
Can you add anything to the conversation between my 2 minds to give me a definite answer Al? Which one is right? Or, are they both right, or are they both wrong?
The influence of many leads to the individuality of one. - E.C.C. (That's me!!)
Unread 09-02-2006, 15:29
FRC #0519
Re: Old and New
The reason I asked the question is because the way are robot is laid out, the quick disconnect connector from the battery to the IFI Breaker panel is not long enough. Of course we could buy or make an extension to fix that problem, but we already had the ground stud mounted and wired and at this point we didn't really want to start redesigning are electrical board. But from the replies I have received, I think I'll have to buy or make an extension.
Unread 09-02-2006, 15:33
Unsung FIRST Hero
Rookie Year: 1996
Re: Old and New
Please ask this in the Q&A so we can get some clarification. Electrically, there should be no reason that it would be illegal. You could, after all, purchase an insulated crimp splice for #6 wire to extend the wire and be legal. (I would recommend replacing the #6 with a longer wire or move the breaker panel closer.)
Al
WB9UVJ
www.wildstang.org
The old man is gone Aaron Lussier Chit-Chat 0 04-05-2003 12:54
New Computer Help Show! MattK Chit-Chat 12 03-10-2002 21:15
Old or New Weezer? Ryan Dognaux Chit-Chat 12 10-09-2002 20:19
Full list of teams & competitions archiver 2001 14 24-06-2002 00:52
