Go to Post ... You order Thunder Chicken Nuggets at the school lunch line - KelliV [more]
Unread 09-02-2006, 15:51
DemonYawgmoth's Avatar
DemonYawgmoth DemonYawgmoth is offline
AKA: Artem Kochnev
FRC #1396 (Pyrobots)
DemonYawgmoth is an unknown quantity at this point
Send a message via AIM to DemonYawgmoth Send a message via MSN to DemonYawgmoth
How to connect the touch sensor?
We want to use one of the touch sensors that came in the sensor bag this year, and we cant seem to find anything online as to how to connect the touch sensor to the robot controller and such. Where would the wires connect on the RC? Would it plug into a digital input or analog input. I'm guessing analog, but im not sure? Thanks in advance guys.
Unread 09-02-2006, 16:07
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: How to connect the touch sensor?
Do you mean microswitch?
The "common" connection goes to ground, and either the "normally open" or "normally closed" connection goes to a digital input on the RC. You'll read its value as 1 when the switch is open, and 0 when the switch is closed.
Unread 09-02-2006, 16:34
AKA: Artem Kochnev
maybe im doing something incorrectly, but if i test it with if (rc_dig_in01 == 0) and then do some other stuff, would that work? also, how would we print stuff with printf()? we used it 2 years ago but i forgot how to get it to work. Also, i forgot the proper procedure for connecting the RC or OI to the computer to actually get these printf values. Thanks.
Unread 13-02-2006, 00:29
Chriszuma's Avatar
Chriszuma Chriszuma is offline
Jack of all trades
AKA: Chris Hammond
FRC #0068 (Truck Town Thunder)
Chriszuma is just really niceChriszuma is just really niceChriszuma is just really niceChriszuma is just really nice
Send a message via AIM to Chriszuma
Yes, that should work, as long as the stuff you want it to do is enclosed in {braces}. The printf command is very simple.
Code:
printf( "The digital in is reading %d", (int)rc_dig_in01 );
When you download the code with IFI Loader, it should automatically bring up a terminal window that dissplays the printf outputs. (you can also click 'terminal window' in the menu to bring it up).
2006 T3 World Tour: Great Lakes - Waterloo - Palmetto - IRI
2006 Awards: Motorola Quality - RadioShack Innovation in Control
My website: http://zuma.phire.org/
Truck Town Thunder's website: http://trucktownthunder.com/
Bannner IR sensor Measures Ball Exit Velocity Dale(294engr] Technical Discussion 4 15-02-2006 23:57
Making a Sensor Board SpaceOsc Technical Discussion 11 15-05-2004 12:46
heres the code. y this not working omega Programming 16 31-03-2004 15:18
Quick Optical Sensor Question zorro Technical Discussion 10 21-01-2003 06:39
How do you connect optical sensor? archiver 2001 1 23-06-2002 23:05
