Go to Post FIRST teams procrastinate and slack off?!?!? The question is, if you do it in a way that keeps your grandmother proud, would that make it "Gracious Procrastinatism?" - Mr MOE [more]
Unread 11-02-2006, 04:09
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Chain Tensioners
I need to tension chains and cannot use the method of sliding one sprocket. The sprockets are fixed. I need to add an additional adjustable roller or something. The tensioning roller itself cannot be a sprocket though due to space and time constraints. The tensioner can only be supported on one side. Automatic (spring loaded) would be nice but not absolutely necessary. The chain is running between two sprockets only. Due to space constraints, I need to push/pull it apart to tension. To room to push/pull together. All parts must be fabricated or purchased locally due to time constraints.
Tonight, I tried a spring loaded pivoting rocker arm type setup and while it worked for the chain moving in one direction, it failed miserably for the chain moving in the other direction. If I had this pivoting arm such that it was not spring loaded but rather adjusted then held in place by friction, would that work? I'd really like an "automatic" spring loaded tensioner if possible, but I'll settle for anything that does the job well enough.
I remember seeing something on this site that was like a plastic sprocket but just the outside ring and it was very flexible and you put it between two strands of chain and it pushes them apart. However, now, I can't find it. I know I said parts must be purchased locally, but if this is an easy and effective solution, we might order them if we know where to get them.
So, basically, I'm desperate for ideas. Pictures are worth 1000 words.
Thanks so much.
Unread 11-02-2006, 04:22
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Rookie Year: 1998
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Re: Chain Tensioners
I remember seeing those rings you are talking about, and recall them only being available in #35 pitch and higher.
I'll take a look and see if I can find it.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 11-02-2006, 04:27
Team Role: Teacher
This is #25 chain connecting two 14 tooth sprockets.
Unread 11-02-2006, 07:16
Jizvonius's Avatar
Jizvonius Jizvonius is offline
AKA: Jevawn Roberts
FRC #1002 (CircuitRunners)
Rookie Year: 1997
Jizvonius is just really niceJizvonius is just really niceJizvonius is just really niceJizvonius is just really nice
Send a message via AIM to Jizvonius
You can try a floating tensioner depending on the diameter of the sprockets and the center distance (if it's too far, the tensioner will just make the chain touch for 14 tooth sprockets). This should work the same in both directions. as for not using sprockets for the rollers, you could use plastic sliders (preferably something like UHMW polyethylene or acetal)
How exactly to implement it would be dependent heavily on the dimensions of your design. but to get the basic idea here is a picture.
You could have a bottom slider with rails/bolts and a top one with through holes. Then you just need to tighten using nuts above the top slider.
Jevawn Roberts
Georgia Tech Mechanical Engineering Senior
Co-Leader - GT FIRST
gtfirst@robojackets.org
1997-2007 w00t for robots!
108-132-408-832-1002
5 teams worth of head scratching
Unread 11-02-2006, 07:42
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
Team Role: Teacher
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
i'm using the pulley tensioners that came off of the big CIMs, since we aren't using them for anything else. the parts you are talking about are called 'roller chain tensioning rings', and can be found on mcmaster-carr using those keywords, but are only available for #35 pitch and up, as travis said.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 11-02-2006, 08:32
Lisa Perez's Avatar
Lisa Perez Lisa Perez is offline
FRC #0573 (Mech Warriors)
Lisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond repute
We've used cylindrical nylon (about 1" in diameter) across the chain for OCCRA before, and it worked pretty well.
Event Coordinator - Center Line District Event
Volunteer Coordinator - Michigan State Championship
Lead Mentor - Team 573, Mech Warriors
Former Mentor - Team 830, Rat Pack and Team 3182, Athena's Warriors
Proud Alumna - Team 573, Mech Warriors and Team 1, Juggernauts
Unread 11-02-2006, 09:14
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
... [shortened to take up less room]
Thanks so much.
Why not use something really simple, like a piece of HDPE or delrin rod with an off-center hole in it? My team (228) has used this successfully for the past two years, and it works great. Plus, it is: 1. Easy to manufacture. 2. Can be cantilevered. 3. Simple! Here are some diagrams/pictures of it in use on our 2005 robot:
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Unread 11-02-2006, 18:20
lukevanoort lukevanoort is offline
in between teams
AKA: Luke Van Oort
lukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond repute
Send a message via AIM to lukevanoort
Grab some idler sprockets from McMaster (page 959) some U-bolts (many McMaster pages) and some springs (also many McMaster pages). Then, put the idler on the u-bolt, then mount the U-bolt so it goes through a plate of sheet metal, finally put a nut and washer on the end of the u-bolt and squeeze a compression spring between them and the sheet metal. A bad ASCII art diagram follows.
|| || bolt tops and nuts/washer
{} {} springs
[][][][][] sheet metal
\\{}// bottom of bolt and idler top
. {} bottom of idler
Team 1219: 2009 - Mentor
Team 587: 2005 - Animator, 2006-2008 - Team Captain
Unread 11-02-2006, 23:59
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
s_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond repute
We had to do the same thing. We took the cheap and simple approach. We put a nylon washer on both sides of a nylon spacer and slipped it all over a bolt. The bolt then just bolted through a hole in our frame. We are using two of these nylon spacer contraptions on each of our loose chains. It's really sturdy, and gives our robot a nice growling sound when we fire it up at full speed.
Unread 13-02-2006, 10:09
Dick Linn's Avatar
Dick Linn Dick Linn is offline
no team (Synergy)
Dick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond repute
Send a message via AIM to Dick Linn
One year, we used wheels off of an old skateboard. We put it on a wood lathe (or was it the drillpress?) and cut a groove to fit the chain.
Richard Linn
Proud father of Marine LCpl. Karl R. Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 13-02-2006, 17:31
Mentor Dave's Avatar
Mentor Dave Mentor Dave is offline
Renegade Engineer
FRC #1800
Mentor Dave will become famous soon enough
For our robot, we used 2 different sized hole saws - the larger diameter circle for the 2 outside pieces, and a smaller diameter circle goes in the middle to make the "groove." We bolt them directly to the frame. They don't have to turn, the chain will just wear against the wood.
We did consider cutting a slot in our frame so that the tensioners could be adjusted, but we deemed it unnecessary.
Unread 13-02-2006, 19:04
Rohan_DHS Rohan_DHS is offline
AKA: Kayla's big bro...
FRC #1620 (Robolution)
Rohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of light
Send a message via MSN to Rohan_DHS
we had some 'C' channel from the kitbot that we weren't using, and we basically cut it, made a groove through it like that (look below), made a slit so that the bolt can slide (not necessarry, i guess, could just use a wing nut, and remove when want to loosen chain), put a bearing on it (represented by the B in the diagram), which pushes up against the chain (labelled C) and tightened the bolt....presto! if you want more info, feel free to pm me
|C|
|B|
[edit]
realized that making the pic better just made it worse
[/edit]
Rohan K
2008: Alumni, Helper
2007: Webmaster, Alumni
2006: Team Captain, Driver, Electrical/Electronics Head
2005: Safety Captain
Unread 13-02-2006, 19:11
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
I saw another thread on here about using that Pulley Tensioner off the big cim motor. I modified a part of the support structure, the L Bracket to be able to mount that onto it and it works pretty well. We also used the spring that came with it to tension it. Our only concern is that pulley being round/grinded down by the chain. I'll post some pictures of it after our next meeting.
Unread 13-02-2006, 20:17
in between teams
AKA: Luke Van Oort
Yeah, I thought about that when designing our tensioners, but eventually decided against it. Unlike idlers, it doesn't supply much resistances to the chain sliding sideways as well as a personal distaste for working with high powered springs. Eventually I had to ditch the design because we needed four tensioners. (Can anybody guess what we're doing? Hint: not omni) shortly therafter came the "block of HDPE" method... threw that one out due to bad experiances last year and an irritating mentor. Then came springloaded U-bolts which ended up mounted statically (although still adjustable) due to a lack of springs and length of the U-bolts. (Originally I planned to use the nice aluminum jobbies from McMaster, but they we're to wide, had to improvise)
  #15   Spotlight this post!
Unread 13-02-2006, 21:41
JakeM's Avatar
JakeM JakeM is offline
FRC #0781 (Kinetic Knights)
Team Role: Mechanical
JakeM is an unknown quantity at this point
If a floating tensioner will work, or to test and see if one will, take some heavy duty zip ties and tie wrap the chain tight, to a reasonable level. Remember the purple and orange powdercoated watercut robot from team 781 2 years ago? These simple tensioners worked perfectly, never getting caught up, and if they broke, they were easy to fix. Once we did get the heavy ties though, there was no breakage.
How To Make Chain With Inventor 10 vVigglEs Inventor 6 28-01-2006 21:34
Chain Drive chain Damelvin 3D Animation and Competition 2 15-02-2005 00:19
25 or 35 chain? Alan Ing Technical Discussion 24 02-03-2003 13:56
1/4" chain and links from small parts archiver 2001 2 24-06-2002 00:18
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
