Go to Post While searching is not as glamorous, I'm certain you could find a lot of good resources related to this topic. - Katie_UPS [more]
Unread 11-02-2006, 11:10
X-Istence X-Istence is offline
Melt the RC controller!
AKA: Bert JW Regeer
X-Istence will become famous soon enoughX-Istence will become famous soon enough
Send a message via AIM to X-Istence Send a message via MSN to X-Istence
Voltage Drop -- Slowdown of motors
Hello,
My team is using three motors, and several other things on the robot, and we are afraid that after the battery is drained, or down to a certain voltage that we won't be able to keep our shooter wheel going at a constant speed for us to shoot.
Now, my mentor suggested we crank up the PWM's more as the current drops by having a geartooth sensor check the speed of the wheel, and once it drops we crank the PWM's.
Will this work? Or will we accomplish nothing, and once the battery is drained it is basically a lost cause anyways, and it is not needed anymore at all.
My Blog!
Unread 11-02-2006, 12:05
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
Re: Voltage Drop -- Slowdown of motors
what your mentor is describing is a closed loop feedback system
yes it will work, the caveat is your max wheel speed will have to be something less than the full speed of the motor.
When the battery is fully charged the PWM values might be 200. Then as the battery gets lower the PWM values will go up, 210, 220...to 254, whatever it takes to keep the wheel spinning at the 'right' speed.
At that point you feedback system will be 'railed' and wont be able to keep up.
Its a great idea: it will hold the wheel speed constant as long as the battery is able to supply the power needed.
BTW, a bonus of this system, when you launch a ball the sensor will see that the wheel has slowed down, and it will increase the PWM output to get it back up to launch speed. This means you will be able to fire sequential shots faster.
Feedback is one of the most powerful tools an engineer has at his disposal!
EDIT: and the spell check is the 2nd most powerful tool (edited for speeling :^)
Unread 11-02-2006, 18:28
AKA: Bert JW Regeer
Thank you very much for the information.
My Blog!
RC Circuits Melissa Nute Math and Science 3 25-01-2004 05:02
Sensing current and/or voltage drop??? archiver 2001 3 23-06-2002 23:21
Looking for practice motors & extra tape drive parts? archiver 2000 1 23-06-2002 22:54
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
Drill Motors TF8 Motors 19 12-12-2001 13:13
