Go to Post Use sensors to collect data about the surrounding environment, then discard it and drive into walls. - Jared Russell [more]
Unread 11-02-2006, 13:27
Unholy Unholy is offline
electrical / makeshift programmer
AKA: Daniel
FRC #1402
Unholy is an unknown quantity at this point
Send a message via AIM to Unholy
issues limiting a joystick input
I'm trying to limit the speed in a motor through programming in in such a way that when the joystick is fully deflected, i will only get a response of, let's say, 93 instead of 0, and 150 instead of 255. The way the joystick is set to work is that it won't be engaged unless the trigger is closed. Initially, as soon as I clicked the joystick trigger, my value would change automatically to 0 from 127 using a command looking like this:
if (p3_sw_top == 1 )
pwm03 = (((p3_x) *2) / 10)
Initially I thought I had issues with the trim, but I checked the trim using pwm03 = p3_x;, set it to neutral, went back to the line above, and as soon as I clicked again, my value was 0 again.
I'd appreciate any help I can help, and sorry for this noobish question
-Danny
2006 CMUcam2 Code Kevin Watson Programming 81 10-02-2007 20:17
Free programming help Cuog Programming 24 24-01-2006 16:43
Change joystick to pwm mapping Joe Lewis Programming 3 30-03-2005 19:27
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
joystick problem archiver 2000 12 23-06-2002 23:08
