Hi,
When trying to build my code in MPLAB 7.20, I get a strange error:
Clean: Deleting intermediary and output files.
Clean: Deleted file "C:\FIRST\2006\FINAL CODE 2-07-06\camera.o".
Clean: Deleted file "C:\FIRST\2006\FINAL CODE 2-07-06\camera_menu.o".
Clean: Deleted file "C:\FIRST\2006\FINAL CODE 2-07-06\eeprom.o".
Clean: Deleted file "C:\FIRST\2006\FINAL CODE 2-07-06\ifi_startup.o".
Clean: Deleted file "C:\FIRST\2006\FINAL CODE 2-07-06\ifi_utilities.o".
Clean: Deleted file "C:\FIRST\2006\FINAL CODE 2-07-06\main.o".
Clean: Deleted file "C:\FIRST\2006\FINAL CODE 2-07-06\serial_ports.o".
Clean: Deleted file "C:\FIRST\2006\FINAL CODE 2-07-06\terminal.o".
Clean: Deleted file "C:\FIRST\2006\FINAL CODE 2-07-06\tracking.o".
Clean: Deleted file "C:\FIRST\2006\FINAL CODE 2-07-06\tracking_menu.o".
Clean: Deleted file "C:\FIRST\2006\FINAL CODE 2-07-06\user_routines.o".
Clean: Deleted file "C:\FIRST\2006\FINAL CODE 2-07-06\user_routines_fast.o".
Clean: Done.
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "camera.c" -fo="camera.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "camera_menu.c" -fo="camera_menu.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "eeprom.c" -fo="eeprom.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "ifi_startup.c" -fo="ifi_startup.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "ifi_utilities.c" -fo="ifi_utilities.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "main.c" -fo="main.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "serial_ports.c" -fo="serial_ports.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "terminal.c" -fo="terminal.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "tracking.c" -fo="tracking.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "tracking_menu.c" -fo="tracking_menu.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "user_routines.c" -fo="user_routines.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "user_routines_fast.c" -fo="user_routines_fast.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD
Executing: "C:\mcc18\bin\mplink.exe" /l"C:\mcc18\lib" "18f8722.lkr" "C:\FIRST\2006\FINAL CODE 2-07-06\camera.o" "C:\FIRST\2006\FINAL CODE 2-07-06\camera_menu.o" "C:\FIRST\2006\FINAL CODE 2-07-06\eeprom.o" "C:\FIRST\2006\FINAL CODE 2-07-06\ifi_startup.o" "C:\FIRST\2006\FINAL CODE 2-07-06\ifi_utilities.o" "C:\FIRST\2006\FINAL CODE 2-07-06\main.o" "C:\FIRST\2006\FINAL CODE 2-07-06\serial_ports.o" "C:\FIRST\2006\FINAL CODE 2-07-06\terminal.o" "C:\FIRST\2006\FINAL CODE 2-07-06\tracking.o" "C:\FIRST\2006\FINAL CODE 2-07-06\tracking_menu.o" "C:\FIRST\2006\FINAL CODE 2-07-06\user_routines.o" "C:\FIRST\2006\FINAL CODE 2-07-06\user_routines_fast.o" "C:\FIRST\2006\FINAL CODE 2-07-06\FRC_library.lib" /o"camera.cof" /M"camera.map"
MPLINK 3.90, Linker
Copyright (c) 2004 Microchip Technology Inc.
Error - section '.idata_user_routines.o' can not fit the section. Section '.idata_user_routines.o' length=0x0000010b
Errors : 1
BUILD FAILED: Sat Feb 11 18:06:42 2006
What does this mean?
I'm using Kevin Watson's "Bells and Whistles" camera code and I've added a bunch of code, running the drive, our shooter, and our harvester.
Can anyone shed any light on this subject? Thank you.
