Go to Post Uhh... we were supposed to be building a robot? *looks at giant wooden Trojan Rabbit in the corner that was built instead for the past 6 weeks* Whoops... - Adam Richards [more]
Unread 11-02-2006, 21:09
Idaman323 Idaman323 is offline
In Theory, Our Robot Would Own.
FRC #1706
Team Role: Driver
Idaman323 is an unknown quantity at this point
Default Code
Hey guys, I got Kevin's CMUCam code finnaly on the robot.. the weird thing is.. nothing moves. I have the pwm03 and 04 as p1_y and p2_y. and I left the pwm 01 for the pan and pwm 02 as the tilt under tracking.h. In the user_routines, I have it set on p3_y, p4_y. Am I suppose to do something with those? Or just leave them as that?... Also when the program is loaded.. on the window, it is saying "Searching..." or "P1 Y 127, X 127" Or any of those coordinates on it. The regular default code runs this fine, but when I load the camera code with all of those changes... nothing happens. Am I suppose to do anything special to make them run. Hmmm, Im confused.
Thanks,
Idaman323
TEAM 1706
2007 Judges Award, St. Louis (For our amazing ability to have bad luck)
2005 Rookie Inspiration Award, St. Louis
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Modified default code gives "code violation" scottmso Programming 8 10-02-2006 23:17
default camera code edit Windward Programming 8 25-01-2006 18:33
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
heres the code. y this not working omega Programming 16 31-03-2004 15:18
