Where to get flanged R6 bearing locally
I'm looking for a bearing identical to the Small Parts brf-06. But I need it immediately. I think I know a place, but in case they don't have it, are there any local chain stores that would have this size flanged bearing? What about Motion Industries. Does anyone know if they carry this size bearing. Or maybe Applied Industrial? 3/8" ID, 7/8" OD flanged.
Re: Where to get bearing locally
I found this page very interesting... http://www.thomasnet.com/nsearch.htm...eading=3650207 Last edited by Arefin Bari : 13-02-2006 at 00:21. |
You're looking for a standard flanged R6 bearing. Any industrial supply store that carries bearings should have them; if you can survive without a flanged bearing, it should be easier still to find them.
I cleaned out the handful of 3/8"-bore flanged bearings (one of several sizes on hand) stocked at our local Ace Hardware. Admittedly, it is a freakishly-well-stocked Ace (they also carry grade 8 fasteners), but you might try a similar local vendor. McLendon's hardware also carrys things like this, but that won't do you much good unless you live in Washington.
Sorry. ![]() EDITED TO ADD: Dood! You're in LA! If you can't find bearings within 30 minutes of your house, I'll fly down and go shopping with you. Grab the yellow pages and start dialing for parts tomorrow morning. I thought you were in some remote part of the country or the Valley or like that. Last edited by Rick TYler : 13-02-2006 at 00:37. |
For the ones you got at Ace, were they the cheap junk ones or good ones?
I remember the frustrations of trying to find 3/8" and 1/2" ID Flanged Bearings from back when I was on 229. I recommended that IFI sell the ones we get for our wheels in kits (the bearings come with a set of our retainer hardware.
They are available on this page: http://www.ifirobotics.com/robot-traction-wheels.shtml |
Are they flanged though? If so, and I order Monday night, is there any way I could get them by Wednesday afternoon?
Motion Industries does carry them. FR6-ZZ is flanged double shielded.
#10
Dave,
AndyMark sells these bearings as spare parts for the AM Shifter 2. FR6ZZ You can order these individually, for $5 each. Get the order in by noon your time, pick Express delivery, and I will make sure you get them via FedEx next day air. They can be yours tomorrow. Andy B. |
#11
Try Mesa Bearing. I think they are in Huntington Beach area. Last year I talked to Bob and he got us some great deals on bearings.
Kirk |
#12
Off topic, but I thought this was some good info on bearings in general: http://www.gizmology.net/bearings.htm
| Looking for smaller 1/2 ID ball bearing | sanddrag | Technical Discussion | 6 | 26-05-2005 19:44 |
| "Load Bearing Surface" | Natchez | Rules/Strategy | 118 | 04-04-2005 04:36 |
| Ratchet/slip bearing? | Ianworld | Technical Discussion | 6 | 20-01-2005 13:04 |
| bearing help | jimfortytwo | Technical Discussion | 9 | 01-05-2004 06:20 |
| Need A 0.75" ID bearing .DWG | Tytus Gerrish | Inventor | 6 | 22-10-2003 11:23 |
