Go to Post Honesty and Integrity is the key to success. If I don't teach my team to be honest, I am a failure! - team4384 [more]
Unread 13-02-2006, 00:42
jaustin jaustin is offline
AKA: Jeff Austin
FRC #2930 (The Taterbotz)
jaustin is an unknown quantity at this point
Wall Following Anyone?
Hi,
I was wondering if anyone out there has had any luck using Kevin's pid code to do wall following? I've been trying to use the velocity algorithm to vary left and right motor speeds based on the output of an analog IR range detector. Not having much luck getting a smooth response. It wants to stop and adjust each time it gets too close or too far.
Autonomous Mode Wall Sensor - Ruling Ashley Weed Rules/Strategy 2 11-02-2006 12:56
Frame tubing wall thickness sanddrag Technical Discussion 5 03-06-2005 11:04
My Wall Caught On Fire!---A Classic *Mangia* Aignam Chit-Chat 10 03-09-2004 03:27
Thin Wall Refraction Zing Inventor 0 26-01-2004 16:24
You can't see through an untouched starting wall of boxes Digo General Forum 31 11-01-2003 12:01
