Go to Post IMO, everyone should experience at least one Battlecry. - Dan Petrovic [more]
Unread 13-02-2006, 07:47
gnirts gnirts is offline
Suspicious pointer conversion
AKA: Robinson Levin
FRC #1648 (The Gearbox Gangstaz)
gnirts will become famous soon enough
How does disabled mode work?
I am interested in building a loop that calibrates the gyro bias while the robot is disabled.
1) Is that legal, as long as there are no PWM outputs, etc.
2) What part of the code is running while the robot is disabled? Process_Data_From_Master_uP()? main()? Process_Data_From_Local_IO()? Is statusflag.NEW_SPI_DATA ever set to true? Does that matter, if the gyro is handled in Process_Data_From_Local_IO()?
Thanks in advance,
Robinson
'... who are you, then?'
'I am part of that power which eternally
wills evil and eternally works good.'
Goethe, Faust
Designs that would never work... Cyberguy34000 Technical Discussion 60 09-01-2007 20:56
RC getting spontaneously disabled Shu Song Control System 14 12-02-2005 21:00
A little question about the autonomous mode Anton Programming 4 18-01-2005 14:08
A serious (FATAL) error in the FRC documentation (competition_mode) KenWittlief Programming 17 29-03-2004 13:47
Initializing autonomous mode Mr. Lim Programming 7 02-02-2004 07:26
