Go to Post At this time of the season, there is only one response: BAAAAAAAAA-humbug! - dlavery [more]
Unread 13-02-2006, 11:22
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Pre-Load Arrays in EasyC, Possible?
Can anyone tell us if it is possible to pre-load your array with constant values in easyC? We want to create a lookup table and just need to create a single dimension array and load it with constants.
We have tried to define the constants as show in the screen shot. Look at "power[3]" It's a 1 x 4 array and when we set the value field to something like 0,0,0,0 we get an Error: 1 when we try and compile this.
If we leave it value field blank, such as the variable "sign[3]" then it will compile just fine.
We have tried formatting the value field:
0,0,0,0
{0,0,0,0}
(0,0,0,0)
The only thing that seems to work is leave it blank, then in code somewhere we have to do this:
power[0] = value0
power[1] = value1
power[2] = value2
power[3] = value3
(or write a loop to load up several constants...)
Is this the only way to pre-load the arrays in EasyC?
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
EasyC Wish List dcbrown Programming 32 14-08-2006 09:24
Battery Life, 50A load discharge test method/results Dale(294engr] Electrical 5 22-01-2006 09:14
EasyC v2.0 is mandatory for FVC! skimoose FIRST Tech Challenge 7 14-01-2006 18:37
Kickoff easyC workshop integrated into EasyC help file Dan Larochelle Programming 0 11-01-2006 06:12
