IR Switch Wiring
Can anybody give me some information on how to wire the revieving end of the IR sensors?
Re: IR Switch Wiring
Wire it the way it's labeled on the side of the sensor. Ground the ground wire, put 12 volts (from your 20 amp "sensor power" circuit) on the power wire, and connect either the NC or NO output to a digital input on the Robot Controller.
| Need Help Wiring Micro Switch/Limiting Switch | Windward | Electrical | 2 | 07-02-2006 18:26 |
| Wiring Nasson switch | ten3brousone | Pneumatics | 4 | 19-02-2005 17:16 |
| Wiring a switch | stevex | Electrical | 3 | 16-02-2005 08:31 |
| Pressure Switch wiring diagram | robotjoe | Electrical | 1 | 08-02-2005 14:01 |
| LEDs in switch box. | ZZII 527 | Electrical | 5 | 06-03-2004 19:39 |
