Go to Post I can see the 2013 Kickoff broadcast now: "Hello Teams. Welcome back. Gracious Professionalism. Here's some homework. Here's the animation. Here's what the actual field looks like. RTFM. Peace." - sanddrag [more]
Unread 14-02-2006, 19:57
caderader's Avatar
caderader caderader is offline
caderader
#1284 (DART)
caderader is an unknown quantity at this point
problems programming knob and switch
I am trying to use a knob to control the speed of one pwm motor and a switch to control a spike. If anyone knows how to do this or can help me please do. Thank You.
p.s. if you need me to tell you anything else or give you anymore info I can. Thanks again.
Unread 14-02-2006, 20:07
X-Istence X-Istence is offline
Melt the RC controller!
AKA: Bert JW Regeer
X-Istence will become famous soon enoughX-Istence will become famous soon enough
Send a message via AIM to X-Istence Send a message via MSN to X-Istence
Re: problems programming knob and switch
You need to read the information about the joystick ports, hook up your own potentiometer, and a switch to any one of the digital and analog ports, then program your robot to respond to them on the right joystick port.
For information on wiring, check http://ifirobotics.com/docs/oi-ref-guide-11-21-05.pdf the pages you want are 5 - 10. Good luck.
My Blog!
Unread 14-02-2006, 23:10
caderader's Avatar
caderader
#1284 (DART)
we have already wired the joysticks and i have four different switches and 2 knobs wired. THe main problem was how to call these different things. Btw all these auxillary switches i mentioned aboce are in port 4. As far as i could figure it had something to do with the use of p4_aux.(not sure if thats actually what its called since i dont have the code in front of me) Thanks Again.
Unread 14-02-2006, 23:16
sburro's Avatar
sburro sburro is offline
AKA: Joe
FRC #0663 (crusaders)
sburro will become famous soon enoughsburro will become famous soon enough
Send a message via AIM to sburro
First, I am no programer by far but I will ask for som info I know others might need. Fisrt, we need to know what pins the knobs and switches are connected to. From this info, someone (not me, I do not know enough at the moment) can tell you how to call the values from the switches and knobs.
K.I.S.S
Keeping It Simple Stupid
Unread 16-02-2006, 16:45
caderader's Avatar
caderader
#1284 (DART)
ok what about if i just wanted to make a trigger activate full forward.
