Go to Post Thanks for the wishes of luck. We try to minimize its importance, but having it on our side is never a bad thing. - Madison [more]
Unread 14-02-2006, 21:45
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Motor drive function?
Lets say I want to have a function, that somehow modifies an inputted speed and sets an inputted motor to that speed. Instinct tells me it would be something similar to
Code:
void Drive(int motor, unsigned char speed)
	// modify inputted speed
	motor = speed;
Drive(pwm01, 100);
However, I've tried that and it doesn't seem to work. The motors just don't spin. I'm assuming it is because when you read pwm01, it gives you the current speed that pwm01 is running at. So Drive(pwm01, 100) is similar to, say, Drive(127, 100)
What is the cause of this problem? How can I fix it?
http://www.mikesorrenti.com/
Unread 14-02-2006, 21:58
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Motor drive function?
You need to pass the parameter that will be changed in by address rather than value.
Code:
void Drive(int *motor, unsigned char speed)
	*motor = speed;
Drive(&pwm01, 100);
Unread 15-02-2006, 05:04
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Originally Posted by Keith Watson
The original code just modifies a local copy of the argument passed in. You need to "pass by reference". Typical usage is:
Code:
void Drive(int& motor, unsigned char speed)
	motor = speed;
Drive(pwm01, 100);
Mark's example works but is less common in usage. It takes the address of the variable, passes it in as a pointer, then dereferences the pointer.
Keith,
I think that you are mixing C++ with C. in C++, "int&" is a pass by reference. In C there is no pass by reference only pass by value and a pointer is the only way to do it.
Mike
To All,
Mark's post is correct. Please read K&R chapter 5 before sliding down the perilous and provocative path of pointers.
Mike
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 15-02-2006, 11:55
Keith Watson Keith Watson is offline
FRC #0957 (WATSON)
Keith Watson is just really niceKeith Watson is just really niceKeith Watson is just really niceKeith Watson is just really nice
Originally Posted by Mike Betts
Keith,
Mike
Oops, I stand corrected. I've been using C++ for so long (since 1988) I forgot! I removed my post.
Keith Watson - Professional Software Engineer
No relation to "Kevin" Watson, who created the camera tracking code.
Loop time for OperatorControl function? Debug blows... Chris_Elston Programming 10 13-02-2006 14:42
Arcade Function gabrielse Programming 1 08-02-2006 00:49
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
RoboEmu2(code simulator)--now with C! rbayer Programming 23 17-02-2005 09:17
heres the code. y this not working omega Programming 16 31-03-2004 15:18
