Go to Post FIRST is the most glorious test of the mind. Anyone can run a marathon or get a slam-dunk. It takes guts to admit you are a nerd that enjoys six weeks off non-stop stress, and actually thrives on it. - kws4000 [more]
Unread 22-02-2006, 21:41
Denz's Avatar
Denz Denz is offline
FRC #0772 (Sabre Bytes Robotics)
Denz is on a distinguished road
Send a message via MSN to Denz
Re: Wires Pull Themselves Out
I believe we are using silicon to secure them into place, it would work much the same as hot glue, and it would insulate aswell.
www.sabrerobotics.com
Unread 23-02-2006, 00:36
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
I need to step in here an say a few things about hot glue...
The glue is at or near the same temperature as the gun it comes from. In some cases that is enough of a thermal shock to damage critical electronic components so, no, it is not an industry "standard". Depending on where it is used, it can have other than insulator properties. I would not want to depend on it providing high voltage protection or insulating a temperature critical capacitor. And the one thing no one has pointed out is what happens when you want to remove or modify what is attached with hot glue? It requires getting everything up to the melting point to pull it apart or trying to cut it apart with a knife. Often it goes where you don't want it.
What industry does use (and it looks a lot like hot glue) is paraffin. It is easy to melt, pour, scrape away, reposition etc. Again, there are places you wouldn't use it. (i.e. near a heatsink or other hot component, high voltage or certain RF circuits.)
We found that using square header pins (just like the ones on the RC) which fit snugly and deeply in the connectors work much better than the stamped male pins of a PWM cable. Wires soldered to the end make for a low profile and allows the wires to dress out to the side where they can easily be secured by the enclosure or ty wraps. A little dot of hot glue on each solder point (this is an appropriate use), heatshrink, or electrical tape to insulate the soldered connection (before insertion) works very well, and doesn't damage any of the wire or connectors.
Al
WB9UVJ
www.wildstang.org
________________________
Blue Drill Motor wires? j_pannell Electrical 4 17-02-2004 15:06
update 8 clarification, drill motor and blue wires pryoplasm Rules/Strategy 23 13-02-2004 07:26
What gauge wires Punjabguy87 Electrical 7 07-02-2004 20:25
extra 40amp wires Lord Nerdlinger Electrical 4 14-02-2003 14:53
How hard is it to pull a goal? Ken Leung General Forum 19 17-01-2002 20:09
