Go to Post If FIRST isn't your life, then you're doing something wrong! - BandChick [more]
Unread 14-02-2006, 22:24
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Drilling Dewalt gear for Fisher Price
How do we drill (then ream) the dewalt gear to press on the fisher price shaft? We went in with a ~.120 drill and it made lots of noise. It seemed like it was working, but maybe half way through it broke. The gear seems like a very hard material. Any ideas?
Unread 14-02-2006, 22:55
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Re: Drilling Dewalt gear for Fisher Price
Very hard indeed. I chucked the pinion in a lathe and went throught at around 1200 RPM with a brand new bit a little under .125. Then you want to use atleast a .1250 reamer, if not slightly larger. You'll never get the gear on without bending the shaft if you use anything smaller than a .1250, though.
Unread 15-02-2006, 07:56
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
I definitely don't recommend using a standard drill to do this job.
Even a lathe is trickier that I'd like (though with a very tiny boring bar & small cuts you can do it reliably).
I am a big fan of wire EDM. Fine a local source or use the one listed in the NBD whitepaper.
Joe J.
Joseph M. Johnson, Ph.D., P.E.
Mentor
Team #88, TJ2
pic: GEAR BOX with two speed ericwittlich Extra Discussion 6 19-07-2005 22:01
Fisher price motor gear specs archiver 2000 4 23-06-2002 23:23
Module 7 gear -- fischer price motor archiver 2001 6 23-06-2002 22:55
FISHER PRICE GEAR BOXES archiver 1999 2 23-06-2002 22:07
drilling that chiaphua gear ahecht Motors 8 06-02-2002 01:23
