Go to Post "Friends don't let friends build mecanum" - Michael Corsetto [more]
Unread 14-02-2006, 22:47
Kyveck Kyveck is offline
FRC #1014 (Dublin Robotics)
Kyveck is an unknown quantity at this point
Presence of function causes auton to fail???
I apologize if this will be a little long, but I will try to present our problem clearly and concisely. As of Saturday morning, we had our autonomous mode working beautifully, albeit without any gyro code. In our spare time, we decided to go ahead and patch in some code one of our first year programmers wrote to allow us to use a Flightstick joystick that has some very odd calibration parameters. We began by placing the standard function Limit_mix() that our programmer had decided to use in its proper place in User_Routines.c, and its prototype in User_Routines.h. We had previously deleted it, but we are sure that the new copy of the function is identical to the default from IFI.
With the function and prototype in, and not called from anywhere, the robot only pulses its wheels for about half a second, instead of performing the scripted path that we had set for it. We have checked, and are extremely confident that the function is not called anywhere, and that none of the names in the function occur anywhere else in our code. We modified the code to read:
Code:
unsigned char Limit_Mix (int intermediate_value)
  static int limited_value;
  if (intermediate_value < 2000)
    limited_value = 2000;
  else if (intermediate_value > 2254)
    limited_value = 2254;
  else
    limited_value = intermediate_value;
  return (unsigned char) (limited_value - 2000);  */
  return 2;
Then it worked again. When we uncommented the first if(), it ceased to function properly in autonomous. We then commented the whole function, and created our own for test purposes. When we only made it increment a variable, autonomous worked, but if we gave it an if or while statement, it would cease functioning again. Our controls mentor is now reading up on our code, but hasn't found a problem yet. The only explanation my controls team can think of is that we might be out of program space or memory. Our mentor remains dubious of that, as we haven't gotten any errors from the loader.
Once again, the robot still seems to function properly in everything but autonomous, though we haven't had time to exhaustively test that. I can post more details if anyone needs to know more to guess what is going on. We high school students are afraid that something is probably seriously wrong if the presence of a function is enough to cause a whole module of code to malfunction, especially if the function is never called and is removed far removed from the autonomous module.
Chances are that we are just missing something obvious, but I have had a number of very astute programmers scratching their heads over this in the last few days. If anyone has some insight, or any idea what is going on, we would greatly appreciate any ideas. We are basing our code somewhat on Kevin Watson's scripting code from last year, though it has all been heavily modified to suit our needs. We have quite a lot of code, which lends some plausibility to the idea of us being out code space, and there are a decent number of interrupts in the background, if that affects anything. Thanks for reading this,
Kyle W
Lead Programmer, 1014 Controls Team
(Dublin Robotics)
Loop time for OperatorControl function? Debug blows... Chris_Elston Programming 10 13-02-2006 14:42
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
Auton + Functions ten3brousone Programming 0 27-02-2005 20:11
RoboEmu2(code simulator)--now with C! rbayer Programming 23 17-02-2005 09:17
heres the code. y this not working omega Programming 16 31-03-2004 15:18
