Go to Post My first instinct was inflatable clowns and 5 of them beating on the robots at all times, but then I thought, thats probably not right. - Dan Richardson [more]
Unread 15-02-2006, 00:46
Rick TYler Rick TYler is offline
A VEX GUy WIth A STicky SHift KEy
VRC #0010 (Exothermic Robotics)
Rick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond repute
Tuning PID Code
Help us, Kevin, you are our only hope! Or someone else...
Our programming guy (robotaddict -- my son as it turns out) has written single-stick code based heavily on Kevin's PID code routines. It's been a long, difficult road for a student who had little C experience at the beginning of the season, but the code seems to work pretty well. The wild oscillations are gone, and the robot is drivable. But there are some problems. I'm hoping some of you with real-world PID experience can give John -- er, I mean robotaddict -- some guidance of final debugging. We also use these routines for aiming and autonomous, so it is important that he fix them. John and the programming mentors have tweaked the P,I, and D settings a LOT, but the perfect blend of settings has been elusive.
1. The controls are pretty sensitive. Turning is especially twitchy.
2. Can someone describe the PID tuning process in even more detail than Kevin does in the comments in his code. Careful descriptions of what the robot is doing in relation to each of the control settings would be especially appreciated.
3. The robot nearly drives in a straight line, but gently drifts to one side in a long (say 30-40 feet) drive.
Thank you SO MUCH in advance.
Exothermic Robotics Club, Venturing Crew 2036
VRC 10A, 10B, 10D, 10Q, 10V, 10X, 10Z, and 575
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Problem with idata_user_routines.o? Adrien Programming 3 12-02-2006 01:33
Drive Straight C Code using Encoders without PID? Chris_Elston Programming 17 15-02-2005 23:41
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
heres the code. y this not working omega Programming 16 31-03-2004 15:18
