Go to Post You never know when the GDC will slide in a rule about any robot with a laser must do a laser light show on the floor of the field or face a 50-point penalty :p. - EricH [more]
Unread 15-02-2006, 17:48
SHerpich SHerpich is offline
FRC #0909
SHerpich is an unknown quantity at this point
How should we call camera tracking functions during autonomous mode?
Where, or how, should we call the camera tracking functions to get the camera to track in autonomous mode? Calling the individual Servo_Track and Camera_Handler functions didn't work. We copied Process_Data_From_Master_uP, gave it a new name, commented out the call to Default_Routine, and called that from within User_Autonomous_Code and that didn't work either. We moved things around relative to the getdata and putdata statements, and even tried commenting some of them out, to no avail. The camera stops tracking as soon as it goes into autonomous mode. Any suggestions would be appreciated.
Unread 15-02-2006, 18:33
Keith Watson Keith Watson is offline
FRC #0957 (WATSON)
Keith Watson is just really niceKeith Watson is just really niceKeith Watson is just really niceKeith Watson is just really nice
Re: How should we call camera tracking functions during autonomous mode?
Our User_Autonomous_Code() looks like this:
Code:
  while (autonomous_mode)   /* DO NOT CHANGE! */
    if (statusflag.NEW_SPI_DATA)      /* 26.2ms loop area */
        Getdata(&rxdata);   /* DO NOT DELETE, or you will be stuck here forever! */
        Camera_Handler();
        Servo_Track();
The trick iss to look in Process_Data_From_Master_uP() to see what functions looked necessary and what order things were called in.
Keith Watson - Professional Software Engineer
No relation to "Kevin" Watson, who created the camera tracking code.
camera in autonomous LightWaves1636 Programming 1 12-02-2006 00:20
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Receiving info from OI to select autonomous mode Mr. Lim Programming 21 17-02-2005 00:56
Autonomous With Camera schenkin Programming 20 16-02-2005 23:52
Programming Autonomous mode Jared Stofflett Programming 3 11-11-2003 09:32
