Go to Post Thanks and don't stay up all night waiting for Lavery Claus! - Beth Sweet [more]
Unread 17-02-2006, 01:19
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
5/16" shaft, 3/32" key, and 15N-m of torque
Stall torque on this would be 15N-m. Can a 5/16" shaft with a 3/32 key hold up to it?
Or, if you have any better ideas, I need to get a 13 tooth 20P gear onto a shaft. And I have to do it quickly, soon, and without too much trouble (I'm going to say that LN2 would probably be too much trouble, as would TIG welding).
Unread 17-02-2006, 01:52
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Rookie Year: 1998
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Re: 5/16" shaft, 3/32" key, and 15N-m of torque
Knowing the problem, I would tell you to simply drill it to 3/8" and chamfer the inside of the gear, weld it, and then machine it back down to the initial size.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 17-02-2006, 02:06
Team Role: Teacher
Do you think it would need to be TIGed or could it be MIGed?
Unread 17-02-2006, 03:54
Engineering Mentor
FRC #0254
Rookie Year: 1998
You could get away with mig'in it
-Travis Covington
Unread 17-02-2006, 07:26
DjAlamose's Avatar
DjAlamose DjAlamose is offline
AKA: Teh Albie
FRC #0279 (Tech Fusion)
DjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to behold
Send a message via AIM to DjAlamose
AH! Whats with the welding of gears! Key the shaft and the gear. It will be fine at 15N-m. We had gears in 2004 that were 7" in dia and were under ~240N-m (I believe, could be higher) and we had those on a 1/2" shaft and they were fine with a 1/16 key. You should have no problems with the 5/16 shaft and it would be easier on repairs if it wasn't welded.
WHAT TIME IS IT????? 279!!
2006 GLR Safety Award (2nd year in a row)
2005 National Xerox Creativity Award
2005 National Curie Quarter Finalist w/ 1126 and 180
2005 Buckeye Regional Champs w/ 67 and 274
2005 Buckeye Regional GM Industrial Design Award
2005 Buckeye Regional Safety Award
2005 GLR Quarter Finalist
2005 GLR Xerox Creativity Award
2005 GLR Safety Award
2004 Nationals Curie Division Finalist
2004 GLR Champs
2004 Buckeye Delphi Driving Tomorrow Award
2004 Buckeye Quarter Finalist w/ 1001 and 869
2003 GM Industrial Design Award GLR
2001 National Champs
